Hi I have noticed recently that my Arlo Ultra camera was recording audio sometimes over a hundred times a day.
I created an edit rule to prevent audio activation but this has made no difference.
I charged my camera a week ago and it's now at 58%
Today alone its made over 150 audio activations
Thank you.
Edit: I inadvertently left my base station off for two days, totally forgot about it. So not sure being off for two days is relevant.
Not sure exactly what you did with that rule but try a new mode with identical rule(s) as a test.
And you're sure that it's audio that triggered the recording? In the library, there should be a tag that displays what caused the recording.
It sounds like a hardware problem. Open a case with support:
I have the same problem - did you get a fix? One post said could be firmware needing update but mine says no update available. Problem started randomly a couple of weeks ago
Same issue here, get constant audio notifications even though it's not set to detect audio.
I haven't been able to use the systems for weeks, starting to lose track of when this went sideways.
I downloaded the new app and removed the old one. It didnt change anything. Then I tried removing the power to the central station and putting it back again and voilà now it works without registrating sound. The only problem in the app now is that I cant see everytime in what mode I am in.
I noticed the same problem last night with one of my five cameras.
I do not have "If audio detected" ticked off.
All my recording are set for 60 seconds.
The weird thing is that all the audio recordings are 15 sec long which I never used as a setup.
Anyone else have the 15 sec. recordings?
This is happening to my setup as well. It seems related to smart notifications. Once I enabled smart notifications and asked it to listen for smoke alarms it started recording audio. I turned off the smoke alarm check and it still recorded audio. I then went into "Armed" and turned off audio there for the rules. It still records audio. The preserved videos get flagged as "Audio". There doesn't seem to be a way to turn it off again.
Hi Ryan
Now that you mention this, it all started when I installed the new ios Arlo app, which is when I noticed the smart smoke detector feature. The only camera affected is the front outside camera which is in a noisy environment. I have the smart smoke detector turned off as well, although I did play with the toggle switch. So this is most probably a bug in the firmware.
@JamesC , are you following this tread?
Reposting to display properly.
Hi Ryan
JamesC, are you following this tread?
For those experiencing this issue, try removing the power from your SmartHub, plug back in and test again to see if you still experience the same behavior.
Please let me know if you're still getting audio alerts after power cycling.
Hi JamesC,
I'm still getting 15 sec audio recordings eventhough I have no audio trigger.
Keep me posted.
I'm having the same problem with mine, I noticed it 2 days ago when in was trying to move the audio settings. I get around 100 sound alerts on 3 cameras.
hi, experiencing the same issue. Received a replacement for a faulty camera and once installed am getting continuous audio recordings on just the new camera. This is continuing despite the audio being turned off.
Please let me know how to rectify. It is killing the battery and Really starting to impact my confidence in the product which is important considering this is a home security system.
Thank you for all the feedback provided here. The development team is investigating reports of this issue. I will provide an update with any new information I receive on this topic.
FWIW, I am seeing this also on one of my ultra cameras. Rebooting the base didn't help - neither did switching to default "armed" mode.
Any update on this? I first noticed this yesterday, and it happens with all of my cameras. Audio detection is turned off, as is the microphone. Tried unplugging the base for four hours and plugging back in with no luck.
I was having this problem with 1 of my 10 cameras (i.e. audio triggered 15 sec recordings when camera is not even set to trigger on audio). I've had the camera disable for 2 or 3 weeks and tried a few times to re-enable during that period only to get a flood of audio alerts. I enabled this camera again today and its been about 6 hours and I haven't received any audio alerts. I know there has been an iOS App update - perhaps this has resolved this problem (although it seems strange to me that this would be an iOS App issue). At any rate I'm happy it seems to be fixed for me.
If you were experiencing this problem you might want to try re-enabling your camera. Hopefully I haven't called it too early.
Accessing Local Storage
