  • 7 Replies
  • 7929 Views
MortenBW
Hi,
How do I activate my free 1 year smart plan? I had to re-install and now it is not an option!
Regards
MortenBW,
The free 1 year premier subscription plan is automatically applied to your account when you install the SmartHub. The free plan can only be applied one time.
7 REPLIES 7
MortenBW,
MortenBW
Hi
Sorry for not accepting your answer.
Approx. 2 months ago I bought your top model, Arlo Ultra with 4 cameras. Since there was a software bug in your system, Arlo support told me to reset my setup and start over.
Now I get to know that because followed your instractions I lose my right to 1 year free Arlo Smart. It can not be true.
Regards
Morten
MortenBW,
Did you change accounts or simply remove and re-add the SmartHub to the same account?
bbeagle
My Arlo Ultra pack never gave me the option for a 1 year subscription, so I called support....
They told me to sign up for the 1 month free trial, and they would solve the issue by then. In 1 month, they never called me or solved the issue. So, I called and they credited my account for a 1 year subscription.
MortenBW
Hi,
I did a reset of the smarthub and used same account after..
Regards
MortenBW
anyone from Arlo out there? I can't accept that because of advice from your support, I have lost my subscription - it that the way you do business?
MortenBW,
I will reach out to you in a private message to collect more information on this issue.
  • 7 Replies
  • 7930 Views
