Re: ARLO ULTRA MOTION RECORDING "GOES TO SLEEP"
- Email to a Friend
JamesC, Are you saying that removing and re-inserting the micro SD card is supposed to be a possible solution to the failed Ultra Base Station Firmware update on July 29th?
- Email to a Friend
Hello, there are actually 2-3 different threads on here. Many of those reporting issues discovered that the motion recording to the library was fine until July 29th. Arlo pushed out an Arlo Ultra Base Firmware on July 29th and that's when the problems started. Can you confirm your problems started then too?
- Email to a Friend
JamesC, Yes I have used the SD Card for local recordings. Yes, I disabled that feature as part of the troubleshooting process. Yes, I tried operating without the SD card inserted at all. Question: Why cannot Arlo admit that the Ultra Base Firmware that was pushed out on July 29th is the problem. My motion recording to the libary was working fine until that update was pushed out. We are now at two weeks plus since the problems started and the problem is still ongoing.
- Email to a Friend
I honestly don't know when this issue started for me. I've been having so many other issues, it's hard to keep them straight.
edit: I just looked back, and my thread is from 7/16, so I was having this issue well before the last firmware update (which broke my audio and infrared...)
- Email to a Friend
Which is stupid considering every time it gets rebooted my doorbell will not resync itself with the base until someone presses the button.....
COME ON ALREADY....
- Email to a Friend
- Email to a Friend
Same problem here. I just upgraded to the Ultra 4 camera system and have 6 original Arlo cameras connected to the new hub also. One of the new Ultras won’t record.
- Email to a Friend
- Email to a Friend
Do you mean “ active” , on?
I don’t have Sd , because! I get the PVC plan,
- Email to a Friend
Firts, I like to appreciate all the people that participate, and all the impressions shared with my about this issue.
I scale to 2 level “ Arlo , and they told me to “ restart “ the base station, And, I did it.
then we synced all the cameras ( 4) to the base, and the star wok perfect, and then suddenly one stop working.
I disconnect( unplugged) the base from the power for a few seconds ( like 45 seconds ), reconnecting the base and until this moment ( 24 hours later) still working all good ( cameras) , now detecting motions and recorded to the library.
But I want to download any video from the library the system give me this error.
Cocoa- error( see screenshot attached)
Still persists the error, that Arlo smart don’t “ know “ the different between a Animal,and , vehicle, and this error happens de 96 % of the time during the night,
please give , share with me your experience about this problem.
- Email to a Friend
Anyways, just for those who haven’t tried it, I have done all possible troubleshootings. From a simple reboot to removing and re-pairing the cameras, checking the sensors, and even I tried the hard reset (factory reset) the result of all were the same. Working for 2-4 hours then stopped recording.
I do believe it a firmware issue as its a little chance that both my smart hubs and all 10 cameras hardware defect at the same time!
- Email to a Friend
This is a $700 system of paper weights currently and I am fed up with it. Too bad I can’t return this garbage now
- Email to a Friend
- Email to a Friend
Aspirant that is something in this tech age isn't it when it calls a dog a person and a person a vehicle or animal and once even a bee was a person and a person 10 feet from the camera is just motion. Good thing they can't be used for face recognition. If this system did work as advertised it would be a awsome system and they wouldn't be able to keep them in stock. IF
- Email to a Friend
Looks like they are working on it and what he told me was they expect a firmware push update sometime soon to fix the issue.
So keep checking your libraries for newly recorded videos.
- Email to a Friend
Well it's certainly good news they have come to that conclusion, that it took near 3 weeks considering the number of posts on this dedicated community, not so good. If they all were as quick to respond as James is, then I would be gratefull.
- Email to a Friend
- Email to a Friend
This is not just affecting Ultra. I have Arlo Pro 2 and same exact issues.
- Email to a Friend
- Email to a Friend
JamesC.
Do you have any solution for this issue?
Can you be so kind and share any information related with the subject, that generate all these debate?
- Email to a Friend
Same problem here. No detection, no video recording since a few hours.
- Email to a Friend
I’ll chime in here and follow this thread. All our cameras are also not recording motion events since the last update. I haven’t opened up a ticket at Arlo, but will tomorrow if there is no update.
if I reboot the main unit, turn off cameras, restart them, etc once in a while I’ll get an alert or two then they’ll all go dead again. One time, one camera was active for about 12 hours and had about 120 motion alerts that day. It hasn’t worked since about a week ago when that happened despite restarting it, unpairing repairing it, etc etc
- Email to a Friend
I've had the ultra since 1/16/19 they have been nothing but trouble. Almost every update is a mess, some thing is always different and not working as should. I'm having the same problems as you. Sometimes it picks up motion about 50 % of the time lately. I have been rebooting, remove device, install device. I'm about done. Remember you have a year to return people.
- Email to a Friend
question on the 1 year return apprentice, I thought the Best Buy policy was 30 days. I'm hoping to get it working but if they can't fix the android app to handle doze mode it's useless to me.
- Email to a Friend
Today I received a notification that my support-task has been closed what is leaving me behind without knowing how to continue ... have the software development team found the issue or not?
Will there be a fix for it soon or are the not even investigating it any more?
I'm willing to wait for a fix but if there's nobody actively working on it I doubt it will come back to a working condition just by itself magically and in that case I would imediatelly return my Ultra-System and buy a different one!
Would be really cool to know what's going on ...
