Only showing todays recordings.
  • 18 Replies
  • 2777 Views
Retired_Member
Not applicable
My subscription just ended, so I switched to recording on the SD card in my base station.
Problem is I can only see todays recordings.
Is there a way to see all recordings other than removing the SD card?
Retired_Member
Not applicable
Just found the calander.
18 REPLIES 18
If you have the old user interface (UI) that uses Library to view videos, use the left arrow to the side of the month display at the top to see the previous month's recordings.
Retired_Member
Not applicable
Looking at recordings under storage settings & it still shows only today
So you're using the new UI that has Feed to view cloud recordings? Have you tried using the calendar icon at the top right to see if you can change date?
Retired_Member
Not applicable
Not looking at cloud. My subscription ended a few days ago. The only way I was able to figure out how to view recordings on my SD card was through devices/base station/storage settings and then it just shows me todays recordings.
Is there a better way to view recordings on my SD card in my base station?
Retired_Member
Not applicable
Not sure what the new UI is
The old one has an option for "Library" at the bottom of the main screen.  The new one shows "Dashboard" and "Feed".
Retired_Member
Not applicable
Mine shows dashboard & feed, so new UI.
Still have the same problem
ShayneS
Hi @Retired_Member
Are you still experiencing this issue with your local storage?
Retired_Member
Not applicable
Yes I am
ShayneS
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
Retired_Member
Not applicable
Not any real troubleshooting. Not sure what to look for. Just know that the only way I was able to figure out how to view recordings on my SD card was through devices/base station/storage settings and then it just shows me todays recordings.
ShayneS
Are you using an Android device?
Retired_Member
Not applicable
Yes, a Samsung
Retired_Member
Not applicable
Still looking for a solution
Retired_Member
Not applicable
Need some help
ShayneS
Do you see the calendar/date selector in the top right?
Retired_Member
Not applicable
ShayneS
Awesome, let me know if you have any other questions.
  • 18 Replies
  • 2778 Views
