My subscription just ended, so I switched to recording on the SD card in my base station.
Problem is I can only see todays recordings.
Is there a way to see all recordings other than removing the SD card?
Just found the calander.
If you have the old user interface (UI) that uses Library to view videos, use the left arrow to the side of the month display at the top to see the previous month's recordings.
Looking at recordings under storage settings & it still shows only today
So you're using the new UI that has Feed to view cloud recordings? Have you tried using the calendar icon at the top right to see if you can change date?
Not looking at cloud. My subscription ended a few days ago. The only way I was able to figure out how to view recordings on my SD card was through devices/base station/storage settings and then it just shows me todays recordings.
Is there a better way to view recordings on my SD card in my base station?
Not sure what the new UI is
The old one has an option for "Library" at the bottom of the main screen. The new one shows "Dashboard" and "Feed".
Mine shows dashboard & feed, so new UI.
Still have the same problem
Hi @Retired_Member
Are you still experiencing this issue with your local storage?
Yes I am
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
Not any real troubleshooting. Not sure what to look for. Just know that the only way I was able to figure out how to view recordings on my SD card was through devices/base station/storage settings and then it just shows me todays recordings.
Are you using an Android device?
Yes, a Samsung
Still looking for a solution
Need some help
Do you see the calendar/date selector in the top right?
Awesome, let me know if you have any other questions.
Arlo Ultra 2
Prima di acquistare
