I have an arlo pro and my front camera is on a smart plan. I have activity zones set up for on my drive and my smart notifications are set up to give me alerts on animals, vehicles and persons (other motions are turned off). However im still getting alerts for other motion and all other motions occasionally outside of my zones. Iv searched here but cant seem to find a fix. Anyone with any ideas please?
Please see the 3 screen shots below, hope it helps
Hi @Ziya
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
Which camera(s) are being affected by this? Are the plugged in to AC power?
Its currently running on battery. I do have a power lead running to it but its only on main for charging purpose.
Is this cam recording outside of the zone when the camera is unplugged & plugged in charging? Have you tried to delete & recreate the zones over the web portal?
I have seen in the past deleting & re-creating the zone through the web portal sometimes helps.
Please contact the Support Team to further investigate this issue. You will find several options for here. - Arlo Tech Support
@Ziya wrote:
how have you set your zone like that, with several points?Mine only allows me to have 4 points so my zones are square or rectangle!
Ultra cameras use 8 point polygons for the zones, other cameras use 4 point rectangles.
@StephenB Having exact same issue. Arlo Please look into it on your side as my system has been running just fine for months. Also this has happened before and nothing I do on my end fixes it.
Hi @Tmlarson71
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Hi @Hollowman1
Does lowering your sensitivity help with motion being detected outside of the the activity zones?
No. Modifying the sensitivity doesn't make a difference.
The objects being detected show (car, person, etc) but they are outside of the activity zones so it shouldn't alert me.
No. I have to completely remove the camera and re add. It then works as it should..... for awhile. Since first post I am on my second re-add.
I have the same issue. It started mid-April. Contacted support. They offered no solution. It has to be an issue on their end.
I’m starting to get really tired of all of the issues with the Arlo System over the past two years. It seems like every other update comes with new problems and you start to feel spoiled when your system runs properly for six months straight. I’d rather have a security product that worked consistently and didn’t present a risk of failure at the wrong time
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
