  • 12 Replies
  • 3007 Views
Joetibrani
I am from Australia and when o first installed my cams, there was a software update with the capability to choose what you want to be notified - People, Vehicle, Animal, Others. A few days ago there was a glitch w one of my cams and my app updated itself and lost that capability. Can someone advice on that. Thanks.
12 REPLIES 12
steve_t
Master Master
Can you check that that particular camera is still enabled for Arlo Smart?
Joetibrani
Hi Steve, thank you for the response but where do i go to verify and validate that?
Joetibrani
Hi Steve, attached is a screenshot of my Device Setting - seems like none of my ca ml is Arlo Smart enabled. Is that correct?! If so how do i do it? Thanks.
steve_t
Master Master
Very strange. Under the Arlo Smart heading and I think above "Call a friend" should be a "manage devices". Check your web browser access to see if that menu is there
Joetibrani
Hi Steve i can t access it. That s the thing, i used to be able to. Attached is my base station firmware. Is this the latest? What else should i do?
JessicaP
Hi @Joetibrani,
Are you seeing this problem when trying to check through the web client on your computer?
Joetibrani
Hi Jessica, to date i ve been checking and working on the Arlo phone app. Can you pls elaborate in this client site via computer. Attached is a screenshot of my app as you can see under device setting the Arlo Smart not tied to any of my cam.
Joetibrani
Thank for the link. I went into arlo web portal and realized under 'Manage Arlo Smart', there are no active cameras found. How do i make my cams active?
Joetibrani
What i did i removed my devices, uninstalled and re installed my app, then the Arlo Smart notification. But now it shows both my cams are inactive which is not true. How do i make them active? This is getting to be a pain.
When in that screen, use the Edit at the top to activate them.
steve_t
Master Master
As above, click Edit and you should be able to drag each one to a section that activates smart for them
