I am from Australia and when o first installed my cams, there was a software update with the capability to choose what you want to be notified - People, Vehicle, Animal, Others. A few days ago there was a glitch w one of my cams and my app updated itself and lost that capability. Can someone advice on that. Thanks.
Can you check that that particular camera is still enabled for Arlo Smart?
Hi Steve, thank you for the response but where do i go to verify and validate that?
Hi Steve, attached is a screenshot of my Device Setting - seems like none of my ca ml is Arlo Smart enabled. Is that correct?! If so how do i do it? Thanks.
Very strange. Under the Arlo Smart heading and I think above "Call a friend" should be a "manage devices". Check your web browser access to see if that menu is there
Hi Steve i can t access it. That s the thing, i used to be able to. Attached is my base station firmware. Is this the latest? What else should i do?
Hi @Joetibrani,
Are you seeing this problem when trying to check through the web client on your computer?
When in that screen, use the Edit at the top to activate them.
As above, click Edit and you should be able to drag each one to a section that activates smart for them
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
