I have the Arlo Smart premier, which is either not smart or smarter than I
I have un-checked the animal and motion icon alerts. But it keeps alerting me with both with multiple recordings. Why ????
This issue should be fixed now but the development team will keep monitoring this issue. Please monitor your Smart notifications and let us know if you're still experiencing this issue.
Hi meddo1963,
Could you elaborate more on what you mean with getting alerts with multiple recordings when uncheckng the animal notification and motion icon alert?
In the smart Notifications in settings, you can edit the motion alerts. I have the animal un-check, I do not want it to see animals. But with this un-checked, it still alerts me for animals. I have a mid size shepard that sets it off all the time. I only want it to recognize people and cards
People and cars, sorry misspeld
I want it to record for people and cars only, not animals
Have you tried toggling the Smart notifications by toggling off and on? Also try this through the web client on your computer.
Keeps seeing the animals when I turned it off
You can try to reboot your Base Station or SmartHub to see if that'll help. Otherwise, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
JessicaP. Could you please look into this personally as I too have this same issue. The stock answer to "contact customer support" will only result in them asking us if we have done all the same things we have already done. And then they will open yet another ticket which will go un acted on for weeks.
I am sure all of us Arlo customers are more than familiar with the "unpair/pair/reboot/unplug...etc. mantra. We do it in our sleep these days.
Please look into this and let us know what is being done to correct it.
Yes, it would be great if You Jessica solved this. I am paying for a yearly subscription that is not delivering as it says. I have re-contacted customer service only for them to say they'll get back with me ??? It sounds like quit a few people are having this issue. I have done everything you requested with no resolution. Thanks
Hey Reallyconfused and meddo1963,
Try to change your Smart settings again and wait for 30 minutes and try testing again to see if that helps.
Again? Don't you think I have done exactly that over and over? I think Arlo is missing the point here.
I have done that multiple times, all with the same outcome. It does not work, it will alert me to animals. It alerts me with my dog or cats. 90% of my alerts are from animals. I have tried the website and phone, multiple times.
This needs to be fixed, I paid for the smart subscription to be able to edit what alerts me. It doesn't work.
I've tried everything you suggested multiple times, needs to be fixed.
It’s irritating enough that I need to keep pulling down cameras to delete and pair again just to keep them working on a basic level
We appreciate both of your patience in regards to this. Our development team is looking into this and would like to verify if the issue is still persisting for you both.
Yes, I am still having this problem.
and Yes, I did as you ask with no fix
Please, lets get this resolved ASAP
Thank You
Yes. It’s been an issue for some time now. The usual “fix” does nothing.
This
So there is a screen capture of the settings for my "Smart" service which is costing me money. And also a link to the video which I am alerted to even though I should not be.
The settings don't affect recordings (everything is still stored). But they should disable animal alerts.
Did the alert say an animal was detected? Or did it say something else?
You might also try disabling "all other motion".
I have tried that too, with no success. On the phone app and the website. I have tried everything that was suggested so far. It still recognizes animals, from small cats to my medium size dog. 90% of my alerts are caused by my animals.
Please fix this
Yes, 90% of the alerts do say animal detected
@meddo1963 wrote:
Please fix this
I don't work for them, so I can't fix anything. The most other users can do is help troubleshoot.
Understood. But you haven't answered the question - are the alert messages saying that an animal was detected, or are they saying something else?.
Yes, animal detected
I cant speak for others, but I would not be adding my questions and comment's to this thread if I were not getting Animal Alerts! I am fully aware that everything gets recorded. However, my iPhone should not be receiving alerts containing animals.
Its amazing how much we need to repeat ourselves in this forum.
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
