- 2
I am having the same issue. This has been extremely frustrating. I am paying for the Arlo smart but the whole purpose of the smart features isn’t working. I have done all trouble shooting possible and the problem isn’t fixed. This isn’t an issue with our end it started happening after the last update. Right after the mobile app changed I noticed the “AC not connect zones disabled” message.
Hi everyone,
Thought I'd share an update. I've swapped my two cameras to see if that makes a difference. Unfortunately not. I did have a person from arlo contact me and we spend some time trying to resolve. We could get the activity zones to work when the camera was in a living room setting with movements within a meter. Since then not much luck. I've restarted and reconnected camera's, no change. The firmware on the camera is 1.125.11.3_26229
I have attached a photo below with the activity zone, at the moment I am getting 20+ motion detections, plenty of cars passing on the road clearly outside of the activity zone. Making matters worse, the battery lasts only a couple of days, I swapped batteries last night, it's gone from 100% to 68% in 24 hours, making 28 recordings of 20sec on average. I am thinking of connecting to powersupply for a period to test, then again, I am starting to think I've got a bad bunch of camera's as neither zones or batteries seems to be working. Or maybe it simply doesn't like where it's been placed!
I just installed 6 Ultra cameras and setup the activity zones. Still get alerts and recordings for movement outside these zones. This is ridiculous Netger what is wrong???
We understand that your camera is detecting outside of the zone that you have created . If the cameras are detecting the outside zones, kindly try the steps below and provide us a feedback with the results.
1. Click on Mode.
2. Select Camera on the left.
3. At bottom click on "Add a Mode".
4. Create a name for the new mode such as "Activity Zone Only Mode"
5. Then go in and customize your activity zone and such.
6. Save.
Repeat for other cameras as need be. That should stop the notifications for activity outside of the activity zone.
I tried this but it still didn't work. The Activity Zones are not an option when configuring a new Mode with rules. I assume that I'm supposed to set the activity zones first, then create the new mode? I had no luck.
Create the zones in Sttings, My Devices, your camera, Activity Zones. Create your newmode and add a rule for the camera.
@jguerdat I tried that but no luck
Hi Slew!
What finally fixed this issue for me on this past Saturday (yay!).
Is deleted my 3 'activity zones' from the Arlo iOS app and re-created them from the web portal on a laptop.
Now since I have 'vehicle' notifications un-ticked from the smart notifications. If vehicles pass through areas of my cameras now I will not receive push notifications from the Arlo app on my iphone. But take note they are still recorded and in my library.
thank you!
Be aware!
Arlo pro 2 cameras on batteries - do NOT support Activity Zones.
They tricked us. It should be clearly stated in advertisements.
Hi Slew!
thank you!
If you untick vehicles notification it wouldn't send push notifications regardless of the activity zone. I think in your case it shouldn't send any push notifications if activity is out of the defined zone. Does it work like that? I don't think this activity zone feature works at all...
Does the Activity Zone feature not work? This was advertised as being part of the feature set on the box.
@Snuffles wrote:
I just bought the system and have this exact same problem. I’ve had about 70 notifications and recordings of cars driving past that are outside of the zone I selected. My battery is solar powered and it’s down 10% at the moment. My notifications are still climbing.
Activity zones can filter out unwanted recordings. But they cannot improve battery life.
There are two types of activity zones - local activity zones (processed in the camera), and cloud activity zones (processed in the cloud).
Local Activity Zones require AC power to the camera (not the solar charger). They don't affect battery life, since the camera has to be powered to use them.
Cloud activity zones work w/o AC power, but require the camera to stream all detected motion to the cloud for analysis. Streams with no motion in the zones are discarded, others are saved. So they don't improve battery life either.
The best option (if you can) is to adjust the camera field-of-view to remove as much extraneous motion from the view as possible. Another option is to reduce the motion sensitivity in the camera rules.
As far as @Aklare's comment - cloud activity zones have required a subscription since at least June 2018, and probably earlier. IMO, there is no bait-and-switch - though it is true that a lot of people who've opted into the trial subscriptions are surprised when the feature goes away when the trial ends. It could probably be more clearly communicated, but I think the main issue is that people simply don't read anything in the click-through agreements or the FAQs on the web site..
@Aklare wrote:
the trial period should be less than the return period so you have a chance to return the product if you don't like it or is stopps working as advertised.
I wouldn't want that. Longer trials are better.
One aspect is that the return period is controlled by the reseller, not by Arlo. So there's really way to do it.
Perhaps an email when the subscription is activated would address your concerns? Though based on the app rollout a couple months ago, a lot of people will miss the email.
But this is off-topic. The poster has activity zones working, but they can't improve battery life.
Yes, the activity zones are not working despite all the trouble shooting. This happened around 3rd week in April 2020. The customer service goes through the motions but they can not fix it.
The zones don't work. They did work until mid April 2020. I returned my system to the store and got a new one. It still does not work. The only way to fix is Arlo needs to fix the coding.
I have the same issue. The activity zones stopped working mid April. I contacted support and they went through their script of resetting the base station, removing and adding cameras, etc. Nothing worked. The representative finally disconnected the chat. Nothing has been resolved. This company is a joke, and I am paying for Smart Premiere and not getting the benefit of the activity zones.
- 2
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
