Issues with Access Sensor not working. Door Open Sensor Function
  • 2 Replies
  • 4595 Views
BigBrother
I have four sensors that will not detect the magnetic door access changes. (One of my 5 sensors is completely dead, another story)
I'm not sure what I'm doing wrong but I get no sensor readings other than CLOSED.
I have enabled Access on each device but when I move the magnet away from the sensor there is no change registered. I have examined all the settings and all the help docs. This does not seems to work.
ALSO, When you go into the access enable page and turn on ENABLE and Chirp, then exit the Access option page, then go back into the Access Enable Option page > Chirp is off. There is no way to turn on Chirp.
BigBrother
Unplugged/plugged the keypad and  that fixed it.
Hmmm... Dunno what to say about the door always closed issue. Is the sensor mounted right side up? I don't think I ever checked but is it possible there's a right side up on the magnet (I never noticed that to be the case)? My magnet is to the left of the sensor, if that makes a difference.
I checked my sensor settings and chirp is on and stays on. Maybe a removal and new setup is needed? Have you tried resetting the sensor?
https://kb.arlo.com/000062968/How-do-I-factory-reset-the-Arlo-All-in-One-Sensor
BigBrother
