Saphod
Hi,
I’ve got the new Arlo Secure App on iOS 18.2.1 on an iPhone 15 Pro.
App version 5.4.0 (8887) from 4th January 2025.
App is also installed on my wife’s iPhone 13 Pro and she was invited with restricted access.
Location services are both set to “Always”. Background app refresh activated. Both accounts logged in on their respective phone.
My wife’s status does not seem to make a difference. When I leave home and my wife stays, the “Everyone leaves” automation is activated…
… which is not what it should do. I have to set it back to stand manually.
Any idea what the issue could be?
Best answers
  • BrookeN
    The development team is currently testing a fix that will be made available in an upcoming version of the Arlo app that we hope to release very soon. Once we have more information available about this release, we will provide an update. We apologize for any inconvenience caused.
  • BrookeN
    The development team was able to reproduce the issue as described and is continuing to work toward a solution. As soon as we have more information available, we'll post an update.
  • BrookeN
    We are still currently investigating this behavior. I will update the community as soon as possible.
315 REPLIES 315
@BrookeN wrote:
@StephenB are you seeing this behavior as well?
 Leave failed to trigger when I went out this morning.  Leave did trigger when I went out in the afternoon, but Arrive failed to trigger when I returned home.
Both automations are set up with "Specific People"  My iphone is the only geofencing device, and of course is selected.  But the failures also happened with "Everyone Leave" and "Anyone Arrive".
They began misbehaving on 24 January.  I'm not sure when I upgraded to 5.4.2, but I think it was around that time.
BTW, Location In/Out Notifications are enabled on the phone, but I never see any.
Saphod
@StephenB:
I had location notifications on as well and can confirm that I never saw one.
BrookeN
Can I get a screenshot of your edit Geofence screen please.
BrookeN
Hello all,
I just wanted to do a quick follow up and see if anyone is still seeing this same behavior?
@BrookeN wrote:
Hello all,
"Arrive" is still misbehaving for me.
As a sample of 1, ours is working mostly ok. It will still occasionally miss us leaving but, if I enable Arm Away manually, it will switch to Arm Home normally.
As I posted above, if "Arrive" is enabled in both "Arm Home" and "Arm Away", it triggers reliably when the system is in "Arm Away".  But if "Arrive" is enabled only in "Arm Away" (as it normally should be), it will not trigger reliably for me even though the system is in "Arm Away".
I retested that when @BrookeN followed up, and it is still happening.
"Leave" is always enabled in my setup, and that does work reliably.
@jguerdat wrote:
It will still occasionally miss .
IMO, geofencing needs to be rock-solid to be useful.  If you need to check the mode when you go out or return, you might as well just change the mode manually.
BrookeN
They are still investigating this. I do not have any further updates as of today. I will update you as soon as possible.
BrookeN
I just wanted to check in and see if anyone is still seeing the same behavior with the secondary account?
I won't speak for anyone else but our GF has been working well recently. Hopefully it stays that way.
pekkav
Hi,
I just bought Arlo cameras and app works fine with my iPhone 15 pro but not my wife's iPhone 16 pro. I have re-installed app many times, and logged with my account, doesn't work. In settings, there is no option give permission to use location. In my phone it works well.
So when you fix this bug?
There is, but not in your account.  That needs to be done on her phone (after all, it is her location).
pekkav
In iPhone settings? No, it's not. Or do you mean in Arlo app? Can you add screenshots so I know where to search it.
Start by having her
  • press the profile icon in the upper left
  • select the privacy center
  • select "Available Geofence Devices"
Make sure her phone is on the list.  (While there, make sure it has a unique name).
Also go into the Apple Settings, and open the Apps Section.  Select Arlo Secure.  Make sure
  • "Location" is set to "Always", and "Precise Location" is turned on.
  • Background App Refresh is enabled.
  • Location In/Out Notifications are turned on.
alex_loo
Virtuoso
Virtuoso
hi @BrookeN , if you are specific about @Saphod 's scenario, where a "secondary account" is granted access by the primary account, then I do NOT have any input.  Since I always have my phone and my wife's phone logging in the same primary account.
Having said that ...
... I can see the (incorrect) behaviour as experienced by @Saphod here too.  Since more than 12 months ago.  And I have submitted my data log for ARLO troubleshooting too.  So far, I have seen no improvement at all.
Alex
