  • 12 Replies
  • 5136 Views
Oljordan
Hi
I'm using a Samsung S22 ultra and my arlo secure version is 4.0. 4.28512
I tried this morning to log in to my app but I can't.
When I fill my email and Pwd nothing happens.
I reset my Pwd but still nothing.
Thank you for your help
Oljordan
Hi there
Issue has been solved !
I had to log in to the arlo web portal and modify the 2FA verification method.
The 2FA was selected on my previous phone model and not my email.
I selected the email and then i could log in with the app and confirm my new phone as a secure device.
now it's working.
Thanks to all of you who helped me
regards
12 REPLIES 12
ShayneS
Can you try the latest version of the Arlo app 4.1?
Oljordan
Hi
I already did the update yesterday but I stii have the issue
ShayneS
What happens when you press login after entering Email/Pw manually? DO you have a screenshot of the error message?
Oljordan
I fill my login / pwd manually
When i press connect i have the loop in the middle saying it's working and then few sec it comes back to the login portail
You can find a video of my issue there :
https://drive.google.com/drive/folders/1QnPctXGLcv_CQMNuALrElV1j-s6H9XCP?usp=share_link
ShayneS
Thanks, I informed the dev team and I will provide ore info as soon as possible?
Are you able to access the web portal for the time being?
Oljordan
Yes
I can log the my web portal and have access to my cameras.
But with the app no
ShayneS
The team is investigating the provided log.
Oljordan
Hi ShayneS
I just got an update from Samsung.
Now I'm on OneUI 5.1
Unfortunately I still have the issue.
ShayneS
Thank you for the update, I added that info for the Dev team.
Oljordan
Hi ShayneS
For the records I have also a Samsung S23 Ultra.
I made a fresh install of Arlo app and I have the same issue.
Do you have any news from the dev?
Thank you
Oljordan
Hi there
now it's working.
regards
ShayneS
Thank you for the update, I'm glad to hear it's working.
