Can't setup Emergency Response
  • 23 Replies
  • 10081 Views
  • 2 Likes
  • 5 In Conversation
Jshea26731
I am having problem setting up Emergency Response. I hit set up and it says please wait and it does nothing. Please help.
23 REPLIES 23
ShayneS
Are you still experiencing this issue? Which version of the Arlo mobile app do you have installed?
Jshea26731
ShayneS
Have you tried removing and re-downloading the app?
Jshea26731
I have done that a million times. I even went in a cleared all the cookies.
ShayneS
Do you have another device/phone you can try with?
Is this on iOS or Android?
Which version of OS is installed on your phone? Also, can you provide a screenshot of the error?
Thank you
Jshea26731
I have already tried on another phone and iPad.
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
MartiniSlacker
I have exact same issue.  Been working with Support for 2 days now to no avail.  As soon as I upgraded to new Arlo Plus Secure (to go from 5 Cameras to 8 )the Emergency Response Set Up was lost and now I cannot Set it up again.   Have tried different devices, different networks nothing works.  This is 100 % on your back end please fix this!  You “forced” this upgrade and broke critical functionality.
ShayneS
Which version of the Arlo app are you currently using as well as OS on your phone/device?
MartiniSlacker
I am using Arlo app version 3.6.4 (3405) and iOS 15.3.1
ShayneS
Does this issue occur with the latest version of the Arlo mobile app v3.6.5. if you do not see the update you can remove and re-install the app.
Jshea26731
Still does not work with the update.
ShayneS
Hi @Jshea26731
Did you receive my PM regarding the App log?
ShayneS
Does this still occur on version 3.6.6?
ShayneS
@Jshea26731
I received your log, thank you!
ShayneS
Are you still experiencing this issue with the latest Arlo app update 3.6.6?
secure123456
This is happening to me too! I have talked to so many different support people and no one can help me.
ShayneS
Hi @secure123456
Can you provide more detail regarding the issue you are experiencing?
MartiniSlacker
I no longer need resolution of this issue, I downgraded my subscription and lost access to the emergency services feature.
ShayneS
Thank you for the update, please  let me know if you have any other questions : )
Mgfuchs
As a new owner/subscriber to Arlo products I’m particularly upset that this issue has been active for at least 11 months and the problem still exists. The app will not respond to any touch on the residence-type page. (iPhone 12 iOS 15.6)
ShayneS
@Mgfuchs
Which version of the Arlo app are you using?
ShayneS
Hi @Mgfuchs
Do you mind sending me a PM with your contact details/best time to reach you and a member from my L3 team will be reach out to you.
