I am having problem setting up Emergency Response. I hit set up and it says please wait and it does nothing. Please help.
Are you still experiencing this issue? Which version of the Arlo mobile app do you have installed?
Have you tried removing and re-downloading the app?
Do you have another device/phone you can try with?
Is this on iOS or Android?
Which version of OS is installed on your phone? Also, can you provide a screenshot of the error?
Thank you
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
I have exact same issue. Been working with Support for 2 days now to no avail. As soon as I upgraded to new Arlo Plus Secure (to go from 5 Cameras to 8 )the Emergency Response Set Up was lost and now I cannot Set it up again. Have tried different devices, different networks nothing works. This is 100 % on your back end please fix this! You “forced” this upgrade and broke critical functionality.
Which version of the Arlo app are you currently using as well as OS on your phone/device?
I am using Arlo app version 3.6.4 (3405) and iOS 15.3.1
Does this issue occur with the latest version of the Arlo mobile app v3.6.5. if you do not see the update you can remove and re-install the app.
Hi @Jshea26731
Did you receive my PM regarding the App log?
Does this still occur on version 3.6.6?
@Jshea26731
I received your log, thank you!
Are you still experiencing this issue with the latest Arlo app update 3.6.6?
This is happening to me too! I have talked to so many different support people and no one can help me.
Hi @secure123456
Can you provide more detail regarding the issue you are experiencing?
I no longer need resolution of this issue, I downgraded my subscription and lost access to the emergency services feature.
Thank you for the update, please let me know if you have any other questions : )
@Mgfuchs
Which version of the Arlo app are you using?
Hi @Mgfuchs
Do you mind sending me a PM with your contact details/best time to reach you and a member from my L3 team will be reach out to you.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
