 - 2
In the Arlo android app I am unable to create an automation that uses "Anyone Leaves" ? There is no option for that. The only option I see is when "Anyone Arrives". Whats going here and why is there no option to set when anyone leaves?
I am on the latest version of the app, ver 6.4.6_6040602
Best answers
Thanks for letting me know. This symptom has already been reported, and a fix is currently in the works for a future app update.
Pixel gets updates sooner than the others because it's a clean version of android. I have a Samsung S24. Hopefully I get the update soon and this fixes the problem.
Pixels get OS updates sooner, not app. My Pixel 9 still hasn't updated to the new app.
No idea on Android. With iOS going into the app store and searching for the app will generally give me an "update" button instead of the usual "open". That shows up before the apple store pushes the update to my phone.
I suspect removing/reinstalling the app might install the newest version.
This is not an option with Android, iOS functions a little differently, so yes, you may be able to remove and re-install the Arlo app on iOS to receive the update but not Android.
I see the update now thanks. My geofencing isn't working as expected though. It doesn't change when i depart and arrive at home. Yes I have location turned on etc
Can you post screenshots of the automations? One common mistake is that people set the enable list at the top incorrectly.
That said, most of us have found that it doesn't trigger reliably enough. I find that Arrive in particular frequently doesn't trigger.
 - 2
2  -
						Arlo 4.1 App release notes
1  -
						Arlo app
1  -
						arlo not working
2  -
						Arlo Pro 5
1  -
						Arlo Pro 5S 2K
1  -
						Arlo Secure 4.0
2  -
						Automation
1  -
						cameras
1  -
						custom modes
2  -
						Friend
1  -
1  -
						Grant Access
1  -
						my.arlo.com
1  -
						notifications
2  -
						Pro 5s
1  -
						Security System App
1  -
						Temporary disable
1  -
						Vacation override
