  • 30 Replies
  • 1116 Views
  • 2 Likes
  • 7 In Conversation
bondibro
In the Arlo android app I am unable to create an automation that uses "Anyone Leaves" ? There is no option for that. The only option I see is when "Anyone Arrives". Whats going here and why is there no option to set when anyone leaves?
I am on the latest version of the app, ver 6.4.6_6040602
Best answers
  • ShayneS
    Hi @bondibro
    Thank you for the feedback, This issue should be resolved in app version 6.5.0, which is currently rolling out gradually. Once you’ve updated, please let me know if you’re still able to reproduce the issue.
  • ShayneS
    Thanks for letting me know. This symptom has already been reported, and a fix is currently in the works for a future app update.
30 REPLIES 30
cwinters
Pixel gets updates sooner than the others because it's a clean version of android.  I have a Samsung S24.  Hopefully I get the update soon and this fixes the problem.
alex_loo
Virtuoso
Virtuoso
and @bondibro @cwinters , in case this info useful to you, my android app here on pixel 6a has just been updated to 6.5.2.  Dunno what it fixes though.
Alex
Pixels get OS updates sooner, not app. My Pixel 9 still hasn't updated to the new app.
No idea on Android.  With iOS going into the app store and searching for the app will generally give me an "update" button instead of the usual "open".  That shows up before the apple store pushes the update to my phone.
I suspect removing/reinstalling the app might install the newest version.
ShayneS
@StephenB
This is not an option with Android, iOS functions a little differently, so yes, you may be able to remove and re-install the Arlo app on iOS to receive the update but not Android.
bondibro
I see the update now thanks. My geofencing isn't working as expected though. It doesn't change when i depart and arrive at home. Yes I have location turned on etc
