Automatons - Arrive and Leave - No option for Leave
In the Arlo android app I am unable to create an automation that uses "Anyone Leaves" ? There is no option for that. The only option I see is when "Anyone Arrives". Whats going here and why is there no option to set when anyone leaves?
I am on the latest version of the app, ver 6.4.6_6040602
The app defaults to Anyone Arrives and at first it appears that's all you can add. However, click on the name ANyone Leaves and that section becomes active for you to choose.
I see people arrive twice, look at this screenshot. Looks like its an issue with the APP
@jguerdat wrote:The app defaults to Anyone Arrives and at first it appears that's all you can add. However, click on the name ANyone Leaves and that section becomes active for you to choose.
The latest app has made some changes:
- ARRIVE now must be "anyone arrives" (vs choice of anyone or everyone, in the past). This is not a show stopper at least for my typical use case scenario, thoughI find this change unnecessary
- LEAVE now must be "everyone leaves" (vs choice of anyone or everyone, in the past). This is not a show stopper at least for my use case scenario, though I find this change unnecessary.
- When "Everyone Leaves" or "Anyone Arrives" is clicked, the app shows 2 sections, each detailing geofencing devices to be considered for geofencing. This is good move that at least user can tell if ARLO is considering the correct devices for geofencing (vs wrongly repeated geofencing devices in the past)
- Within this screen showing 2 sections, the lower section is incorrectly labelled. It should be labelled "People Leave", instead of "People Arrive". Apparently they haven't got any testing team to even check out the changes (not to mention about testing)
Whatever good or bad points above, BASIC GEOFENCING ROUTINES ARE STILL NOT WORKING RELIABLY.
Alex
fdsad
Correct, how can they not even check the labels so this works as expected. The app is of poor quality and its clear they care very little if they can't even get the labels right.
FWIW, I am not seeing this bit on iOS.
Thanks @jguerdat for following this up
Thanks for letting me know. This symptom has already been reported, and a fix is currently in the works for a future app update.
I think the problem is more than just the second one being labeled incorrectly as People Arrive when it should be People Leave. I appears to actually trigger a People Arrive automation as when I leave my mode show that Standby was triggered instead of Arm Away, even though it was already in Standby when I left.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
