Automations help setting up geofencing
- 2
I recently updated to the latest Arlo Secure app (4.9.1) and also added the new doorbell to my existing camera setup. When I try to set up an automation (Arrive/Leave) I am only given the option to set up "Arrive". As a result I cannot advantage of the geofencing feature to arm/disarm my system when I leave/return. Any ideas on how to remedy this issue?
Thank you!
@sdalext70 Do you have your device(s) listed as a trusted device?
Sharing doesn't affect geofencing. WHat I was asking for in a screenshot was of the screen after you clicked on Anyone Arrives which looks similar to the attached screenshot.
Yes I do
Understood. Please see attached. I think this what you are referencing....
No idea how that is totally blank. Which app are you using - Android or iOS?
I have an iPhone so iOS. When I spoke to the engineering team, they mentioned that a few other customers reported the same issue back in September. They have supposedly fixed the issue on the back end and so they are bemused that I am still having issues.
I'm thinking it is an iOS app issue. Can you temporarily install the Android app on a friend's phone for testing and then delete it?
I don't know anyone with a Android phone.
My Spouse has an android so I can try that. Thanks for the suggestion.
Hi there - Good news! Issue has been fixed. I assume that it was done on the back end, but I checked the automations today and I was able to add the leave function! 🙂 Thank you again for your help!!
- 2
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
