  • 37 Replies
  • 8205 Views
  • 4 Likes
  • 7 In Conversation
alex_loo
Virtuoso
Virtuoso
While 5.5.1 disappeared for update for some time, 5.5.2_28806 has been pushed out!
Same question: has anyone updated to it, what bugs does it fix?  Does it fix the following outstanding ones?
  • geofencing not working all the times
  • cannot pause playback of (locally?) recorded footage
  • (any more?)
Alex
37 REPLIES 37
alex_loo
Virtuoso
Virtuoso
so according to this message,
✔️5.5.2 fixes these:
  • cannot pause playback of (locally?) recorded footage ( @secaz could you share your experience?)
❓Unknown as to whether 5.5.2 fixes these:
  • (any more?)
Any new bug introduced?
@JP-FR  @Trusti
Alex
JP-FR
@alex_loono new version available for me yet, waiting...
Trusti
alex_loo
Virtuoso
Virtuoso
thanks@Trusti .
It seems the pause thing was fixed, not because of 5.5.2, see this message
So I don't really understand what 5.5.2 does.
Alex
alex_loo
Virtuoso
Virtuoso
updating ...
✔️ 5.5.2 fixes these:
  • cannot pause playback of (locally?) recorded footage (reference) ( @secaz could you share your experience?)
❌ Confirmed NOT fixed yet by 5.5.2:
  • "library" version crashing when clicking push notification (reference)
  • (any more?)
booxman
Keep me posted.
alex_loo
Virtuoso
Virtuoso
updating ...
  • (any more?)
❗New bug?
  • leave home automation not working  (reference)
Alex
JP-FR
i updated to 5.5.2 28806 and always the same issue, i think we are forced to get a plan...
BrookeN
@JP-FR what is the behavior you are seeing? Can you provide more information?
JP-FR
I have no plan, for many weeks now i can't access local files, LAN or WAN are same.
clear cache, reinstall...
No files in feeds, no file in device/storage
if i put the SD card on my laptop SURPRISE the files are here and can be played.
I updated to 5.5.3 28810 few minutes ago and... same...
alex_loo
Virtuoso
Virtuoso
I have started discussion on 5.5.3.  Let's jump to there.
Alex
alex_loo
Virtuoso
Virtuoso
do you have link to the original message where your brought this up in details?
Alex
JP-FR
I didn't make a specific message for that
alex_loo
Virtuoso
Virtuoso
sounds like your case is a separate one (at least no other community users are complaining about this)
The ARLO system doesn't seem to recognize the SD card, even though the card is "normal" by itself.
Have you tried telling ARLO app to format the SD card (and of course erasing everything there), before trying to recognize it again?
If so, I would suggest trying another SD card (format from app) as my last resort.
(The first key step I'd like to achieve is recognizing the card from the app)
Alex
Trusti
I also just updated to version 5.5.3 28810.
No change here either. Problem still exists.
"Library" version crashing when clicking push notification https://community.arlo.com/t5/Arlo-Secure/ARLO-android-app-5-5-2-28806/m-p/2441006#M12172%3Fcid=1213...
I'm guessing you have a VMB5000 (since other bases would need an adapter to use a microSD card).  Is that the case?
Do you have another device you can try installing the app on?  For instance an iPad or Android tablet?  Or maybe test with a family member's phone?
alex_loo
Virtuoso
Virtuoso
are you able to share these screenshots?
  • DEVICES >> (base) >> Storage Settings
  • DEVICES >> (base) >> Storage Settings >> Local Storage Settings
Alex
JP-FR
@alex_loo
Here are the screenshoot, I set the language to English 🙂
Screenshot_20250225_142017_Arlo Secure.jpgScreenshot_20250225_142039_Arlo Secure.jpg
@JP-FR wrote:
@alex_loo
Is your phone connected to your home wifi when you see this problem?
JP-FR
Yes when i am on my wifi (LAN) i have the problem.
For your other question i have a VMB5000 and 2x ULTRA 2
I think generally the app is the problem.  But you've taken the steps that tend to rule that out.
If you have no other devices to try, then I think the next step is to remove the cameras and base from the account, do a paper-clip reset on the smarthub, and then add everything back.  Definitely a PITA, but this step was needed with one of my own smarthubs (not recently though).
alex_loo
Virtuoso
Virtuoso
agree.  Something is not right with the hub.  On one hand, it DOES read the SD card (and shows card usage), but on the other, "error obtaining your library" (even if there is no recording saved, it should show just blank, not "error")
And @JP-FR , just to make sure this before you take these big suggestions by @StephenB --- have you reset the hub via DEVICES >> (hub) >> (hub) >> "Restart" button ?
Alex
alex_loo
Virtuoso
Virtuoso
@JP-FR , any update on this?
JP-FR
@alex_loo
sorry, yes i restart the hub and still have the problem...
