Arlo Q is not recording to my USB drive, my other 3 Pro 03 cameras do.
Is there a way to to have Arlo Q record to the USB drive, as well as the cloud?
Message 1 of 4
1,838
Unfortunately not. The Q connects directly to the cloud using your home wifi. It doesn't connect to the base at all.
Message 2 of 4
1,834
Message 2 of 4
1,835
Thank you. 1 follow up question:
Since the Arlo Q doesn't connect in that manner to the base station, does the Arlo Q count towards a unit in the Arlo Smart Plan? Say you have 5 Pro 3 cameras, and 1 Arlo Q, is there a charge for the Arlo Q?
Message 3 of 4
1,828
All cameras in the account are counted - it doesn't matter what base they are on (if any).
One workaround is to put the Q in a different account, and use grant access to let you see all 6 cameras from the main account.
Message 4 of 4
1,826
Arlo Q
