Arlo Q Installation, cannot activate
  • 1 Reply
  • 4168 Views
London
I am running an Apple system and currently use the Time Capsule for my Wifi connection. I am unable to activate my Arlo Q cameras. Is their a solution in place in which I could install my cameras today?
I'm not familiar with Time Capsules but it could be an SSID or passpharase issue.  Make sure you don't use non-allowed special characters in either or the connection will fail.  There's an FAQ here about that - check it out.
If necessary, you can try enabling the guest WiFi capability if TC supports that.  A WiFi extender may be useful if it's something about the TC but I'm skeptical that it would help.
