Can I connect my Arlo Q to the base station?
  • 4 Replies
  • 25963 Views
  • 14 Likes
AngelG
Hi,
I have a base station with one wireless Arlo and one Arlo Q.
Can I connect this Arlo Q to the base station not to my WiFi? The reason is that the router is old 150MB and I beleave the base station has better coveredge.
Unfortunately, you can't.  I have a thread in the suggestions forum about his - add your kudo to add emphasis:
https://community.netgear.com/t5/Arlo-Idea-Exchange/Integrate-Q-to-be-used-in-a-mode-with-wireless-c...
Nope, the Q only used your router's WiFi and cannot connect to the base.
Joylove
Can I revive this one. I have 4 arlo wireless and just added one Arlo Q. The Arlo Q is connected to my WiFi and the Arlo wireless are connected to the Base Station. They have different profiles for motion sensing. How can I put the Arlo Q on the Base Station so they all have the same profile?
The_Tipsy
If I could add the Q to my base station I would buy 2 and have them filming through a window when the wireless PIR is triggered to get a full face. I think the two would work synergistically together if they could be set and managed by the same program from the same base station.
