  • 5 Replies
  • 2493 Views
Mawelton
I previously was able to connect to my camera through the arlo app while connected to my data (when wifi wasn’t available). I am no longer able to do this and get an error message saying I need to conmwvr to wifi. Does anyone have experience with this? Is there a setting that will allow me to continue accessing the camera through the app without a wifi connection?
5 REPLIES 5
chawks
I've had this experience consistently when Wi-Fi is activated on my device but not connected to a network. I am able to connect to a camera through the app over 4G LTE/data connection once I've turned Wi-Fi OFF on the device in that situation. FWIW, I'm using Arlo Q cameras only and was able to watch live views of them remotely over Verizon 4G LTE as recent as today.
Have you attempted turning Wi-Fi off and then connecting to your camera when looking to use your mobile's data plan?
Hope this helps!
Cheers,
C
Interesting. What phone and OS? I never turn WiFi off and have no problem whe using cell service.
Mawelton
I have an iPhone operating with the most current update.
I’ve taken a screen shot of the error message I receive. Not sure how to fix this! It used to work great when using cell service and in he last couple of months this is the message I get.
Mawelton
I did just try that. Thank you for the suggestion. Still getting he same error message. I’ve attached it in case it’s something you may have encountered and have suggestions for troubleshooting.
chawks
I've had this issue consistently on my iPad, so also IOS device.
I use an Android phone but rarely use it for accessing my cameras due to the screen size.
Interesting - it looks like you have Wi-Fi turned off and still have the issue. I am still running IOS 10.2 on my iPad due to 12's incompatibility with some other things I do with it. I wonder if that is also a difference if you're running a later version of IOS.
Cheers,
C
