JUST A FYI...
Ive spoken to customer support. They are aware of the issue and have been for about the last hour.
Next level support is working on it and should have a fix soon.
That could have something to do with your ISP. Check your upload and download speeds using speedtest.net and post the results. Does this seem the same if you use another WiFi network?
What have you tried to fix this? Use both a browser and the app. Power cycle the base.
Open a cse with support using the Contact Support link at the bottom here.
Rodfinch,
What is preventing you from logging in. Are you seeing an error message?
Rodfinch,
Consider using the "Forgot Password" link on the login screen and change your password. Are you now able to log in?
The software is now not allowing my phone which has always worked fine up till recently to connect because of a constant Getting Status message . Moto G3 Android 6.0.1
The only way to gain control of the cameras is to turn off the base station and restart .
Evan this is only temporary. Leaving the app and returning finds the same problem.
This is annoying as you leave your home and when returning it means entering the home with the cameras active so that the base station can be reset again .
A lot of people seem to be posting similar messages at the moment. At this stage with no resolution to the issue from Netgear it would seem that they think it is OK for some of their products to not work.
Is there any way to get Netgear to listen to its customers.
I think alot of this problem is something to do with the app, I get it all the time, yet when I log out from the app then log back in i get connected straight away.
Also via a PC browser I have no problems with my system!
I used your idea about logging out and then in again .
It does get me connected so thank you.
It is a shame that people have to try to find a way around Arlo issues without their help. Awaiting the next update with dread.
