october 5th 2017
ive had Arlo for about 6 weeks now and all working fine till yesterday
The problem is with viewing the cameras on my mobile phone as live streaming
all i get is a black screen
have uninstalled several times, synced again checked flash rebooted, turned off and on again.
still records fine in motion mode and i hear the audio fine
also works fine on the laptop
seems could be related to update for the app?
anyone else have the same problems?
what phone device and OS ?
hello,
its a samsung galaxy ace 3
sorry but i dont know what os is?
os is android
OS is operating system.... do you know what version of android?
edit: ..quick look states Jellybean or 4.2
Not sure if newer versions of app run on that versions.... will chk for you if I can
specs states ;
The Arlo app requires the following OS versions:
- Apple devices: iOS version 9.0 or higher
- Android devices: Android 4.2.2 or higher
It could be the last update of app ( ? )
mine is 4.2.2 and it had been working fine, does this mean i need to upgrade my phone?
thank you for replying and for help
Since you have 4.2.2, it should work... as specs say that or better. ( and you had it working before that )
Do you / have you the lasest android app update from the Oct 2 or did the issue start then?
I really don't have any more to offer as help as you did everything I would have suggested already...
Only other thing is to make sure the cam and base FW are up to date.
@JamesC James, is it possible the new app requires a higher level of OS?
hello
thank you for the help and suggestions.
This happened after i recieved the latest update on the app 2nd oct
It worked fine before this
I've escalated this topic. I will post an update when I have more information.
