Arlo app only plays latest selected video no matter what video I select from my library. For example, if I select a video from earlier in the day, it plays the latest one. It was working fine until I updated to latest version of the app. iPhone app ver 2.7.1.
IF THIS IS IOS
this problem has been posted on this board a few times.
it is do to the bad APP 2.7.1 update on Jan 18
you need to call support takes about 15 minutes and open a case#
they wont fix it unless we all open a case
they will tell you delete the app and reinstall it. that does not work !
be sure to get a case#
1-408-638-3750 usa
I call every day for status on my case#
I don’t believe they have any intention of fixing the problem
so far I have paid for 10 days without being able to play the library
they are horrible, especially when they could re release the old app that was working
Of late I can’t select a particular video from a thumbnail to play it. It defaults to the first video of the day and then I have to swipe to the video I want . It’s very annoying. The is app on iPhone 7. It has been okay before. Any fix would be much appreciated
Amrat
Library the video shows but when I try to play it, it defaults to one a few hours before. There are no more videos after that so I can’t even scroll to it. This happens on my iPhone SE but it works fine on my iPad. I have rebooted my phone but it still happened. Any ideas?
https://community.arlo.com/t5/Arlo-Pro-2/iOS-app-2-7-1/td-p/1671812/page/3
Yes, that is correct. I have 5 cameras and 2 different hubs. I'll have to look at a different system. I can no longer reccomend Arlo.
Why I can see only the last video from my iphone while I can see all 7 day's videos from my desktop? Before I could see the all.
Until fix consider Wyze cameras same featues $20 per camera and the app works.
And you get 10 second videos. One every 5 minutes.
Arlo pro library shows most recent recording for all events. Problem began when adding access to another device with a separate email address. Device worked fine with original sign in settings.
I have activity on all three cameras and when I go to library to see activity of all three camera it only shows me one activity (the same one) from one camera. It worked fine before and I have downloaded the most recent update. How does this happen and how do I view the activity from all three camers
Any help would be greatly appreciated.
Hi,
Canyou include what phone, phone model, and operating system version your phone is on? Can you confirm if you see this on the web login? (log into https://my.arlo.com)
Case raise with Arlo support, apparently their team is aware of the issue and they are working on a fix.
Will post with updates on case
It is possible to work around the problem by swiping left on the video to back track to the wanted video. I expect that you will also get frustrated if you have a lot of videos.
It is an iphone 7 using iOS 12.1.3
This problem does not occur using the web login, only with the app
Thanks, we will have the team look into this.
problem started probably on app release.. lost other features such as filter recordings by people or animal. Activity zones have no effect .
Support has been saying 4 to 5 days to fix the problem for more than a week now.
Amrat
