Arlo app only plays latest selected video no matter what video I select from my library. For example, if I select a video from earlier in the day, it plays the latest one. It was working fine until I updated to latest version of the app. iPhone app ver 2.7.1.
because if it is not documented
they will think its a isolated problem not widespread !
on monday they told me when i was on the phone talking to them
in there system it shows its only a handfull with the issue
think about whom you are talking to when you call in ?
just talked to support to check on my case# again
checked yesterday was told the new app was being uploaded as we speak..
well that was not true
today am told they have no idea.. when or if...
maybe others can live with deleting dozens of recordings to be able to view just that one..
if you cant get a case# so its documented
Greetings,
I've searched the forums for anyone asking the same question and have not seen anyone with this same issue...Using iPhone SE with IOS 12.1.3, the Arlo App has worked fine until over this past weekend, when now no matter which video in my library I might try to view, it will only play the most recent video recording in the library. Even if I scroll back to a previous day such as 3 days ago and choose a video to play, tap it's link in the library, it pops back to today's most recent video and replays it.
PC and deskto Mac versions work fine still, so the issue is solely with the iPhone App.
Has anyone encountered this and found a fix?
I have an iphone SE also and the exact same thing just started happening to me, within the past few days.
Is there a way to send an email to Arlo Tech support?
Arlo app has worksd fine until this weekend i can view only the most resent video from the libary from my iphone.
this problem has been posted on this board a few times.
it is do to the bad app update on friday 2.7.1
you need to call support takes about 15 minutes and open a case#
they wont fix it unless we all open a case
they will tell you delete the app and reinstall it. that does not work !
besure to get a case#
1-408-638-3750 usa
One thing to remember is that uploading a new app doesn't mean it's immediately available, especially in Apple's store. It has to be Apple-approved before it's available.
THEY DONT
Thanks for the advice...luckily you even found the post because evidently Arlo's community support site is about as high quality as their app upgrade just was because you can't even find my original post by searching for almsost the exact keywords used in the thread title.
We should all call, hopefully it won't take the full 15 min for all of us, but knowing my luck with most phone "help" folks, my average will bring your wait time down, ha.
Tried all the things others have mentioned but no luck. The only way to view previous on your phone is to watch the latest video then ‘swipe left’ to scroll through to previous. This is obviously a pain in the arse if you start looking at 17:00 and need to view a clip from 09::00 for example.
You need to sort it Arlo!
1-408-638-3750 usa
The Arlo App appears to not be working properly. When I click on any video clip from the last 4 days it keeps showing the last recorded video only. This happens from video clips from any of the cameras. What could be the problem and how do I re-set or fix? Or is this an app issue? This has never happened before.
1-408-638-3750 usa
App has been working fine, however over the last 2-3 days, it will only play back the most recent recording. For example, if I select a recording from 2 days ago, it plays the most recent recording from today. I am not having any issues when I log in to my Arlo account and replay the recordings there.
Thank you!
1-408-638-3750 usa
Thank you!
