Arlo app only plays latest selected video no matter what video I select from my library. For example, if I select a video from earlier in the day, it plays the latest one. It was working fine until I updated to latest version of the app. iPhone app ver 2.7.1.
I just got off the phone with support. They said it is a known issue and their team is working to fix it. Give it a couple of days to be resolved she said.
I have Arlo Q, and this problem happens only with my iPod touch, not with my iPhone and iPad. The latest iOS is installed. Arlo app verson is 2.7.1
I am having the same issues as only latest video recording plays. Others do not and it just keeps jumping back to the latest recorded video. Very frustrating. Hope this gets resolved soon!!
I have this same problem, reported it 3 days ago..
dont believe them that it will be fixed.
if you did not file and get a case number from them they wont remember you andmthey dont care
I am having the same issue on my app. I can only see recent recordings, I cannot see past recordings but they are there in my library. I tried turning off base. Deleting app, signing off. Still not working. Sometimes my recordings in the library are blank, no recordings. Is it a bug in the app? My husband app has been working fine for him, we share the same arlo base. HELP.
I have this issue also. It records videos on all cameras but will only play back the LAST video recored on any device. This is obviusly an erro in a line of code. Fire that code writer and shame on you for not beta testing it.
Have you also found the sensitivity of the cameras are poor at the moment?
Not much use as a security system as it stands, fingers crossed they sort it out soon...
Anyone else having issues with video library playback?
I am on the using most current iPhone App update. When I try to watch any video from the past 7 days it always play the most recent video saved.
Example: I am trying the watch a video from yesterday, when I press on the video it automatically pulls up the most recent video that was saved.
I have tried to close the app and start over and I am not having this problem on the website, just the app.
I recently updated my Arlo app to version 2.7.1 on my iphone. Now I am unable to view past videos. I can see them in my library when I click on them it automatically takes me to most recent saved video. My husband is not having this problem and he has not updated his app. I deleted my device and reinstalled as well as resynced my cameras. Turned my phone off and on. Deleted and app and reinstalled. None of this works. Any ideas on how to fix this?
you need to call support takes about 15 minutes and open a case#
they wont fix it unless we all open a case
they will tell you delete the app and reinstall it. that does not work !
make sure you get a case #
1-408-638-3750 usa
there are a few posts about this issue on this board..
it was do to a bad app update..
on friday 2.7.1
this problem has been posted on this board a few times.
it is do to the bad app update on friday 2.7.1
besure to get a case#
1-408-638-3750 usa
Recent update broke the Library viewing of prior recordings. Now unable to view any prior recordings, even though they show as available in the Library. To recreate problem, go to Library and select a prior day, like yesterday, a few days ago, whatever prior day that has saved recordings, and try to view one of the older video recordings. When you select an old recording to view, regardless of what video you select, only the most recent recording from today is shown.
However, if I download the prior recorded video, it does find and download the proper video locally to phone and I can view within Photos after the file is downloaded. But you can't view any prior recordings using the Arlo App.
Please investigate and correct, and may I suggest the obvious - Actually perform some QA Testing and Regression Testing prior to releasing updates to the world...
1-408-638-3750 usa
Hi @naray562
Which Model phone are you using and what OS is it running? Have you tried to remove & reinstall the Arlo Mobile App?
amen about the quality assurance for sure..
last spring they sent out an update to the base stations and knocked everyone out for around 3+ days
thousands of users ! without any video capture
then the library issues etc.
an update 2 months ago removed all the little icons such as battery (why) because somebody
thought it was ok to do, we could not get quick battery info. (then a week latter put it back in)
its painful because they are just CRAP
they never offer xtra days on your account payment to compensate their lack of QA/ QC
they need to fill pain, then they'll CARE
Is there a way to improve the signal strength ?
I do have my base station plugged into a TP link exstender, otherwise I cant get enough signal for the camera at the otherside of the house.....
