  • 1 Reply
  • 793 Views
Samjessken
I bought a 2 pack and then a 4 pack of arlo pro cameras both came with a base. I am wondering how I can add my 6th camera, I've tried upgrading my plan online and it won't work, is there a number I should call? Or another way I could go about hooking it up? Thanks
steve_t
Master Master
If you can't upgrade your subscription, it may be due to your location. Your workaround is to set up the second base station on a separate account and then grant access to them. Make sure you click "Allow Access Rights"
https://kb.arlo.com/000039122/How-do-I-add-friends-to-my-Arlo-account
