I bought a 2 pack and then a 4 pack of arlo pro cameras both came with a base. I am wondering how I can add my 6th camera, I've tried upgrading my plan online and it won't work, is there a number I should call? Or another way I could go about hooking it up? Thanks
If you can't upgrade your subscription, it may be due to your location. Your workaround is to set up the second base station on a separate account and then grant access to them. Make sure you click "Allow Access Rights"
https://kb.arlo.com/000039122/How-do-I-add-friends-to-my-Arlo-account
