- My Arlo has been offline for a couple of hours. I have internet and the cameras were working fine before that.
I’m having the same dam problem
My #Arlo Pro 2 system suddenly today wasn’t showing any device images (swirling star with ‘device appears offline’ message) with the system disarmed.
I armed the system and immediately was alerted to a new video in the library.
So, the system is working, but the app is not showing me the cameras.
the app is current and was working properly just a few hours ago. Using iOS with the app.
Anyone have insights or suggestions?
FYI, there is a major strike going on all over France, and especially in Paris. Could be related to that somehow.
No, it's not. It has absolutely nothing to do with the events in France.
Cathy, There is a major labor strike happening in France, and especially in Paris. If tech support in located in Paris or nearby, it may be a while before any ARLO technical help happens.
Good Luck.
Mark E.
Recently, all four of my cameras quit working. I checked my app and my base station is reported “offline”. I reset the base station. Same result. I removed the device from the app, reinstalled. Same result. I did a factory reset. Same result. During each reinstall it recognizes the device successfully. It will not update firmware. However, up until I go to click the button to add my cameras it is a successful setup…then reports “your base station is offline”. Both the power and internet lights are solid green on the base station. My Xfinity gateway shows the device is successfully connected to the internet as well. I have never had problems with this setup. What gives?
I am in Paris, and I'm telling you, it's not related. There are a bunch of riots all other France, but the strikes are very focused on specific services, and are largely amplified in outbroad media... Paris is not burning, only a few garbage containers
ANY SOLUTIONS??!!!
I have the same issue!
ALSO THIS IS AFTER UPDATING THE APP!!
I also have this problem. No amount of resets helps. Moving the station to connect direct to the router helps either. My router admin "sees" the base station so I know it's connected.
Miraculously it started working live stream when I checked a few minutes ago!
Live view back. Icons back.
Didn't do anything but issue now SOLVED.
I’m having exactly the same problem. This appears to be an issue with the app. My app said cameras off line, with system disabled. I armed the system and immediately had alarm video of myself in the moment show up in my library.
Have exactly the same issue. System was disarmed, when armed, immediately got an active video show up in the library, all the while the stars are spinning and devices ‘appear to be off line’.
ironically, my other system (I have 2 houses) had a similar issue last week, but it’s worse, the base would not connect to the internet. I took that base to house #2 and it connected just fine. Appears to be an Xfinity issue….
When it rains, it pours…. ☹️
I confirm, everything is back online!
That WAS an arlo's side issue.
let's hope it was a one time event. And that they will start to update their status web page in real time, not every other month...
My ARLO base station and all cameras are working again. All good!
Continues to be offline after several hours..if this is something that ARLO is having issues with, it should’ve been communicated properly…i’ve done everything possible.
what a shame
I'm also experiencing the same problem. I have troubleshot my base station so many times with no luck. I wonder if Arlo is having technical difficulties at this time.
Seems to have resolved on its own this morning. Hopefully yours did too.
Woke up this morning. Everything working fine now. Hopefully everything is working again for you guys too.
Ditto here.
Clearly this was a problem with Arlo’s systems.
Glad they fixed it, happy that nothing happened while it was compromised and somewhat concerned that the “outage” has not resulted in any form of acknowledgement. Corporate denial seems to be the new business standard.
Was able to get the base station to respond and re—add after multiple tries this morning. However, now I have set my system up from scratch, due to following you recommended guides for fixing a non-responsive base station, last night. It would be nice to get an explanation as to how it’s possible for Arlo to remotely brick customers’ systems.
There have been several threads on this. Are things working today? The other threads report all is fine now.
Base shows "offline", and can't connect to cameras, but cameras are happily recording and saving clips to th library. Not a new problem. This problem comes and goes every few months. Also "fixes" the issue... not really... and it is back again. Arlo, please fix the problem! We are tired of it.
There appears to have been an issue with access to the servers yesterday that should now be resolved. Is it?
