3500 base station poor picture quality
  • 1 Reply
  • 994 Views
bhowland7
since this base had firmware update the picture quality has been horrible, I have moved the base and that doesn't even help, I have used 4 different camera's and they all have poor camera quality, I have an older base in a different location and there have been no issues with camera picture quality,  I am going to switch the bases around and see if it helps, but I think it is the firmware update on the 3500 since it always worked just fine before and now picture quality is bad bad bad
DannyBearAgain
The picture quality is generated by the camera is my understanding. Let us know if switching the base station makes a difference.
Can you identify if the poor quality is related to night vision only and does it change when live viewing the camera as opposed to the recordings and if better when using the website login wit pc browser?
