  • 5 Replies
  • 4453 Views
silverado44
Virtuoso
Virtuoso
I have done a search but unable to find my answer. Is there anyway to use one camera motion detection to fire up all cameras? I have done a new mode and I can get it to work but it only lets you use 2 cameras (1 trigger camera plus another to record) I want to use 1 trigger record camera and 2 others to record at the same time. I did 5 new modes but it only lets you select 1 mode at a time. Thanks for any help.
silverado44
Virtuoso
Virtuoso
I figured it out, I had to do the changes on my pc as the mobile app wouldnt let me do it, Thanks again.
5 REPLIES 5
Yes...by making a custom mode as you did...BUT the trick is after making that first custom Mode, go BACK AND EDIT it to add the second camera ( or third )...
You can easily do
Cam A sense, Cam A record
Cam A sence, Cam B record
A > C
A > D
If you want fancy tyou can also "nest" them allowing both ways.
A>A
A>B
A>C
B>B
B>A
B>C
C>C
C>A
C>B
etc
silverado44
Virtuoso
Virtuoso
Thanks for your responce but when I go back to edit I am unable to add a second camera as it takes the first one out.
silverado44
Virtuoso
Virtuoso
Daws
Hi,
How do i actually go about doing this?
I can't seem to find any addtional settings in my account to set it up?
Thanks,
Phil
Read the FAQs here for how to create and edit modes.  Basically, use the Mode tab, select your base and check out the default Armed mode for how things work.  Then create your own mode(s) with the rules you need for the cameras you want active.  Any camera without a rule is disarmed.
