Same issue, started early this morning. Removed and re-added all devices, no change
I just found another thread about cameras not recording to the library and it seems to be the same issue. Started yesterday for a lot of people and still hasn't been fixed. I'm hoping by more people posting that the Arlo techs will work to get this fixed!
I'm having the exact same issue "There was a problem establishing a connection to the media server" started showing up few days ago, everthing worked fine before.
It's not browser or app related, the same error shows regardless of the way I try to connect to my cameras.
I hope someone can provide a solution to this problem.
Happy to report that it looks like it has been fixed at least for me! Feeling much more secure now. Thanks!
Glad your issue was resolved, unfortunantly mine has not. Do you do anything different? Or it just came back on its own?
Gosh, I'm sorry! No, I didn't do anything. Just suddenly started to work.
Just noticed that you have a different base station that I do. Wonder if that has anything to do with it. Maybe they have to do a fix for each model.
Hello all,
I'm a network security professional and just noticed this issue on my Arlo as well.
From my testing, I've found that during power-up and occasionally during operation, the Arlo Pro base station tries to ping Google's DNS servers.
If Arlo is unable to complete this ping, it seems to result in the issue we're experiencing.
Depending on your firewall access, this may show up in logs as blocking ICMP EchoRequest (8) to 8.8.8.8.
Remedy:
1. Configure your firewall to allow outbound ICMP (specifically to that server or in general)
2. Reboot base station
Note: I used the physical power button to restart mine, I don't know if the in-app reboot is sufficient.
Hope this helps!
Getting the same issue. Base has been reset and then resynched. Unplugged/replugged. Disabled my firewall. Still nothing.
Same here. The Arlo webpage tells me that my base station is already running version 1.12.2.0_2790 but with a release date of 3/25....
Can't view live video feeds from the cameras, but recording when triggered by motion seems to be working still.
i'm having the same issue. it started on 4/19/19. My cameras weren't notfying me and when i tried to see a live feed they couldn't connect to the media server. I did a factory reset on the old one and then the app couldn't discover the cameras. I returned the set in exhange for a new one, and i'm having the same issue. Ill be returning this one soon if the problem doesn't get resolved soon.
I am experiencing the same issues. I suspect that the April 19th Arlo Pro Base Station firmware update has broken my entire Arlo system. I have a VMB4000r3 base station and was receiving recordings and able to live stream my cameras until the early morning of April 19th (last recording was 2:14AM). After the latest firmware update, I am no longer able to connect to any of my 5 cameras for live streaming and recording has also stopped.
I have already attempted multiple times to power cycle the base stations and cameras, remove and re-synced cameras, and I have even performed. a factory reset of the base station and re-synced cameras. None of that has worked.
My camera system is effectively useless now. The VMB4000r3 base station is running firmware 1.12.2.0_2794, and the Arlo Pro (H7) cameras are on firmware 1.092.0.19_26228. This is absolutely ridiculous.
I wish we could manually downgrade to a previously working firmware version on the base station. I'm hesitant to disable IDS or other firewall protections (they're enabled for a good reason) and everything was fine until early morning on April 19th, which really makes me think it's correlated with the latest firmware.
I don't understand why the Arlo base station would need to ping Google DNS (8.8.8.8) anyways. I already use 8.8.8.8 as my default DNS server for my home network, but I guess I'll try to allow ICMP outbound to 8.8.8.8 next.
Turned on and off many times, no avail.
i am having the exact same problem!!!!! come on Arlo!!!! Fix it!!!
I am experiencing the same problem and have also tried numerous resets of the base station without any success. This is very frustrating considering that this problem has crippled our entire security system. My initial post can be found at:
I also agree with the previous response regarding having a means to manually change the firmware.
I noticed today that my app has not been sending me motion alerts. I subsequently noticed the last recordings were from two days ago. When I try to live stream I just get the "There was a problem establishing a connection to the media server" and can't get a connection to the cameras.
I've tried rebooting and nothing improves. Two of my four cameras we around 98% charged a couple of days ago now they're both showing 70%. Seems strange to have such a sudden battery drain when they're not capturing or recording any video.
Looking at the other posts here this seems to be a common issue but Arlo are not moving swiftly to respond or resolve the issue. Lucky nobody depends on these cameras to provide security for their homes or businesses!!!!
Opened a trouble ticket no update yet
I have Arlo Pro 2, (7 cameras), all cameras are not recording and I am not getting any notifications, I am unable to connect to the cameras to do live stream. Although I can see the battery levels / charging levels on each camera and the motion sensor seems to go from black to gray. When I try to connect to the cameras to get a live view it times out, although it takes a little while.
I have tried a new switch, I have also replaced the ethernet cable, Internet is working fine, Base Station has three lights with the internet light flickering away... but no alerts, notifications and no recordings at all. I have restarted the base station... etc.
Is this a Arlo / Netgear issue / outage and will come right or is this my issue and I need to try something?
Any advice would be greatly appreciated, have been down for about 24hours and am scratching my head wondering what to do next.
I guess what I am trying to establish is, if this is my equipment or if this is a Arlo / Netgear issue...?
You can spend a lot of time chasing your tail, when the issue was nothing to do with your equipment, but something to do with media servers... etc, in this case it appears that the BaseStation seems to have somehow disabled the cameras and I don’t seem to be able to re-enable them, I don’t seem to be able to connect to a live view...(just times out) but I can get accurate battery levels as I plug in a charger and see the icon change to charging.
My firmware is 1.12.2.0_2794
FYI, I tried BryceD's suggestion to allow ICMP traffic on my router's firewall, and now I'm able to view live streams and receive notifications/recordings again. It was not just ICMP outbound as BryceD stated, I was not previously blocking outbound ICMP traffic. I had to enable inbound ICMP traffic.
After the firewall change, my Arlo system is operational again, but I do NOT consider this a fix. It is simply a workaround because we should NOT have to open up ports on our firewalls for the Arlo service to work; it's stupid and insecure.
Actually, I just did some more testing, and I'm not sure if allowing inbound ICMP traffic through my firewall was a workaround. I've just re-enabled the firewall rule to block inbound ICMP traffic and yet I am still able to view live streams. So I wonder if temporarily allowing ICMP traffic allowed the Arlo Base Station to do whatever it needed to do to get setup properly following the firmware update. We'll see how long this lasts, but I'm glad it's working currently.
Which two green LEDs ??
they are left to right... Power / Internet / cameras.
make sure the phone is on the same network when setting up
Also check if able on browser ; https://arlo.netgear.com
Same issue onmy system. Started 2 days ago, and no matter what I do, it will not record.
To be clear, it only happens with the wireless Arlo Pro cameras. The wired Arlo camera continues to function.
