Did this trial firmware get tested, approved and released?
I just received a notification that there was a new firmware for my base station and I can no longer view live video.
If I try and install the firmware update I get the same behavior as back in April. The firmware fails to install and I have to power cycle the base station to get it to come back online on the prior firmware but live video is still not available as it tells me I need to update the base station.
I'm guessing whatever the fix was that you were testing is either not in this firmware push or the issue is not fixed...
on May 20, 2019 I got a pop up from the arlo application to update the camera firmware, and this update is very good, the sound delay and motion are usually 5 seconds to 1-2 seconds, and do not cause disturbing feedback (if the camera and smartphone close together).
