What phone are you using? Have you tested on the web version if playback works properly?
If you're using an iPhone and iOS 12, there seems to be a video playback issue currently. Try pressing play, then stop, then play, then stop, then play several times, see if it eventually starts playing.
I have the same problem on my iPad using IOS 12. Has Arlo contacted Apple? This is a HUGE problem. It makes the cameras worthless if the video can’t be played back.
Hi @Katwynne,
Are you running the latest iOS version and Arlo app version for your iPad? What iPad are you using?
Thank you for your reply! I tried to find this post to update it but couldn’t. I discovered my iPad had an IOS update ready to be installed that I had not been notified of. The same thing occurred to me and that led me to check my settings. I intalled IOS 12. whatever and the videos started playing.
