Pro camera will not work after firmware update
After recharging one of my eight Arlo Pro/2 cameras and updating the firmware, I am left with a brick.
The camera is entirely unresponsive. I have tried to remove it from my base station and it cannot be added back on. If I plug the supplied charger in, I get a constant blue light for a second or two. Then I get an amber light which flashes twice, and then repeats every so often.
The Sync button on the camera has no response whether I use the battery or not. The camera has bricked. Very unhappy.
That's what warranties are for. Use the Contact SUpport link at the bottom here.
Yes you'd think so. I opened a case several days ago and I haven't had a response. So I'm left with no choice but to seek advice here to try ang get up and running again, even though I see other people have had the same issue but also with no answers. I will continue to wait to hear from Arlo...
I wouldn't wait - keep using the support system to get a response. No idea why it's so painful but keeping going on your end would be the best solution.
HI @Retired_Member
May I ask for your case number you have open with support?
Sure, it's 41962633.
I received a response but the suggestions from Arlo are things that I've already tried, to no avail. The Sync button does not do anything anymore so I can't put the camera into "discover" mode. Nothing changes with power/no power, next to base/away from base, battery/no battery etc. I've tried all the combinations, nothing's happening.
THanks
I don't know why someone changed the name of this thread. I thought "Bricked!" summed it up quite well.
To the person who did change the name of this thread, it's wrong. The camera didn't brick after a base station firmware update. It changed after the camera firmware was updated.
Lastly, the one representative from Arlo who contacted me has left, and after explaining the situation again to the new person, I'm still waiting on a reply. So no solutions yet.
Hi @Retired_Member
I have escalated your case & your escalations number is 41984258. Someone from the support team will be reaching out to you as soon as possible.
Thank you
I have the same problem too ! I just bought the modelVMS4330P not long ago and updated the Station firmware and boom ! camera not snycing and I tried to restart everything and even forget the base station and I can't connect it back HELP !
Hi @danielz99
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
I have tried to chat with support four times and they keep closing the chat box. I have five cameras and four have stopped working since the firmware update. The only camera that still works is different in the hardware number. It is a H4 while all the others are H3 (not sure if that is an why one still works). Regardless I need a fix or someway to reverse the firmware update so the cameras are usable. Failing that I will post what has happened on Best Buy and Amazon and find a camera system that works. If anyone has found a fix please let me know. Thanks..
Thank you Arlo Support! All the cameras are up and working!
@jj77536 what did they tell you to correct the issue?
Push Arlo hard. At first, they wanted me to pay for a new camera which I refused to do, because the camera bricked after *their* firmware upgrade. Eventually, they agreed to a free replacement camera, which arrived even before I had a chance to return the bricked one. So in the end, it worked out, but it took a few calls and a lot of repeating myself to numerous Arlo reps.
HI @Jarhead82
Are you still experiencing an issue with your cameras not charging when plugged in?
Are you using the original charging cable/adapter that came with your device(s)?
