The system I used prior to Arlo cached a variable amount of video, I had it set to 5 seconds, and when an event triggered recording, the video started from this pre-roll if you will.
I installed my camera's on Tuesday. I am not catching the 'beginning' of the trigger event, which could potentially be quite useful. For example, and bad example, I am cathing the snow plow driving across the screen. But it only shows the 'end' of the plow, missing the beginning of the event.
A 3 or 5 second buffer would be a great addition to the recordings.
PittCaleb
The PRO does have a slight pre-record buffer... but not what your thinking. ( the Q cameras go back about 5 seconds as they are always recording )
The pre-buffer on the PRO works a bit different ( TMK ), in that the trigger event ( motion detected by the dual PIRs ) instantly starts recording before sending a notice to the base ( unlike the older Arlo )... the base then responds back and the camera sends all stored and the normal video.
This doesn't seem to answer the question IMO. The member is asking if there's a provision allowing him to NOT miss recording of the snow plow entering the frame. This is especially important as it could very well be a perpetrator's face, a license plate or other evidence.
Thanks.
Is the Arlo Q capable of this?
