Hi @jcaguon
I have a few questions for you.
- Which version of the Arlo app are you using?
- Which version of ios is your iphone running?
Are you a granted access user, or the admin?
My son purchased this product in 2018.
Did you happen to get anywhere with this issue? I'm pretty sure I'm having the same issue as you. Iphone 8 and Arlo Pro setup. The app just crashes as soon as you try to open it. I have removed and re-installed it several times now and rebooted the iphone, as well. Customer support seems to be non-existent unless you have a plan. Very disappointed with them right now. I will never purchase another Arlo product if this doesn't get resolved or I am able to contact or get support from anyone at Arlo. Now I'm wasting my Friday morning trying to contact them anyway I can and searching forums like this. Let me know if you got anything figured out with it, appreciate any feedback.
I was able to login on a iphone 11 pro max as a granted access user. I am not able to replicate this issue. Is it possible you have been removed by accident as a granted access user?
What is the error/denial message you receive? Do you have a screenshot of this?
Funny you ask because Arlo's tech support wanted screen shots, too. A screen shot would be of my homepage as the app doesn't open at all. It flashes and minimizes as soon as I open it or try to switch to it. I was able to sign out and sign in on both my desktop and my amazon fire with no problems. So it's being escalated with them after I spent an hour on a chat with them trying the same thing over and over.
