We are both running the same IOS version - 12.1 and both have the latest Arlo app
Thank you in advance!
Yes, absolutely. We'll see how long it takes them to fix or roll back until they figure it out.
Runnning the same, iOS 12.1 and Arlo Version 2.6.2 with Firmware 1.12.0.0_27099
Running iOS12.1 on iPhone Xs max and having the same issue. The system has always been Okay, but now it is horrible. I was really excited to buy their doorbell and add an aditional camera, but ended up with Ring 2 because of this issue. We need a fix ASAP.
it’s been since the latest update
Yes same here with the update using iphone xmax. This is so inconvenient i cannot see my business or home during this holiday weekend. Arlo please never send an update during a holiday & get this issue fixed ASAP this is unacceptable.
I have an Iphone XS Max and since doing the App update over the weekend it is also freezing my entire phone? Do I really have to download a Beta version of IOS to fix this? Sounds crazy to me? Is the problem an Apple issue and not an Alro issue then?
App only updated on the 22nd Nov, I think it was. It’s the last available update.
Dont get me wrong, when I press it. It does go to the app- but does nothing. It no longer Arms or Disarms the cameras.
1. Thousands of dissatisfied users
2. Negative hit to their reputation
3. Users cannot use the product
4. Loss of trust in the product
I have had Arlo for 2 years now and this has been the worst IOS app version
But in their favour they have only had maybe two or three outages to their systems in the last two years and the hardware is very good
Just the software seems to be going through a lot of change
Good luck
You need to acknowledge this bug ASAP and give us an estimation on an update. This is a big deal.
