I have been having trouble with the new Arlo app ever since I downloaded it. It is much slower, and it is not allowing me to play back videos that are recorded. I read another post about watching the videos on a computer. I hope there's another solution because the reason the app is on the phone is so we can monitor our property on the phone. Please help! This is getting frustrating!
I am having the same problem with video playback on the new Arlo app running on Samsung Galaxy S8.
My Arlo hardware is WMB4000r3.
I'm having this same issue. I updated the app on my android phone and now it won't play library videos unless I connect through wifi. That's not very helpful when you are away from home.
I contacted support and just before our chat started I rebooted the home base. That worked temporarily, but now I am having the same problem again.
Continuous buffering when connected through cell service, works fine albeit slow through wifi.
I am having this issue as well. Started as soon as I downloaded the new app from the google play store. Works fine if I am on a computer but on my phone it just buffers and I cannot view the videos. Never had this problem before the new app.
I'm having the same issues. Since I installed the new app I have been experiencing buffer. How can one use this for one's safety and security of one's home when you one is unable to monitor the cameras. Along with that I recently but haven't installed the Arlo Pro 2 4 pack. I have had the Arlo Pro for some time now. I truly hope they resolve this issue fast.
No live feed
I opened a case with support but yet to hear back from anyone. Seems like ever since I upgraded the app, i have had nothing but problems. Buffering, motion sensors not working, etc. lc
Details.
More than likely a Flash issue..... make sure flash is enabled in your browser.
If an app, more info is needed.
Android or iOS? If iOS, then what version?
@Kevinintx wrote:
I am also having the same issue after the new downloading the new app. Can I install the old Netgear version that worked?
Yes, you can reinstall the old app.
This doesn't seem possible. It doesn't show up as an option in google play store.
Can you offer more instruction on how to use Arlo Legacy version, please?
I'm not seeing there either. But you can get it from https://www.apkmirror.com/apk/netgear-inc-2/arlo/
If you browse to that link in your phone, you will be able to download and install it manually. This process is called "sideloading". If you haven't done it before, you can google "sideload' and your phone name, and you'll almost certainly find an explanation for your device.
Thanks for this info. I will check it out.
It may not be supported, but that doesn't mean it won't work. The one I am using now doesn't work.
I haven't tried this yet. I am hoping to hear back from support today.
Reinstalling and rebooting does not work. Same problem.
I basically have a security system I can't use!
samsung s10
