Pro base station Solid amber light on Camera icon - Device status "Offline"
  • 1 Reply
  • 2275 Views
darolle
WIN_20190925_02_38_12_Pro.jpgarlo offline.jpgJust bought a new ARLO Pro with the base station that came with three cameras. During the device setup APP on my phone, it detected the base station and attempted a firmware update that failed. I retried the update, waited about half an hour but there was no change. I powered the base off then back on but it comes up with a solid amber light on the light with the camera icon. I restarted a number of times with the same result. I then did a manual reset with the reset button but the Same Result. Just got this console so please tell me there is an easy fix for this
One option is to exchange the system with the seller.  Another is to contact Arlo support: https://www.arlo.com/en-us/support/contact.aspx
