I have been having trouble with the new Arlo app ever since I downloaded it. It is much slower, and it is not allowing me to play back videos that are recorded. I read another post about watching the videos on a computer. I hope there's another solution because the reason the app is on the phone is so we can monitor our property on the phone. Please help! This is getting frustrating!
Yes, they need to come up with a solution soon. I submitted a help request several days ago and have yet to get a response back. I think I am going to try to side load the previous version back on my phone.
This is ridiculous.
Will confirm that this worked. My app is working like it did before. The the apkmirror site is not very intuitive though.
thanks to the community members for the temporary fix and NO THANKS to ARLO!
@StephenB wrote:
@Zalin2019 wrote:
This doesn't seem possible. It doesn't show up as an option in google play store.
I'm not seeing there either. But you can get it from https://www.apkmirror.com/apk/netgear-inc-2/arlo/
If you browse to that link in your phone, you will be able to download and install it manually. This process is called "sideloading". If you haven't done it before, you can google "sideload' and your phone name, and you'll almost certainly find an explanation for your device.
It seems once I connect to the wifi first and play a library video then go back to 4g it works till I close the app.
I tried downloading the old version via the APK and this and was marginally better, but not by much.
I would use caution using the download link as there are MANY ads and misleading links to download. You might end up downloading some spam.
I've just updated the app, and I'm unable to play the saved video clips in app (in the library). If I download the clips to my phone's gallery the clips will play just fine.
When I press the large play button on the video clip, the button remains unresponsive and the video does not play.
just got off chat with support. Even shared this thread. They still want to know the following info from me.
For me further check on your case, please provide these information:
1. OS Version?
2. Arlo App version.
3. What is the error message (if there's any) or behavior?
4. Who is the Internet Service Provider?
5. Who is the Mobile Data Provider?
6. From which State or City is the customer from?
7. What is the internet Upload and Download speed for WiFi?
8. What is the internet speed for Mobile Data?
I provided the info but also explained everything worked well until the new app was installed....and that all of you also are experiencing the same issue.
it really seems they don't think their app has an issue, they believe it is our devices/internet/mobile data carrier.
If this is what we can expect with the split from Netgear i feel i have nothing but headaches to come.
Also worth noting. On 4g i can view my camera Live with no issue. So connecting back to the ARLO hub at my house works fine. It is playing the videos in the library...which are in the ARLO cloud storage that doesn't work.
It'd be helpful if we knew the OS version on the devices (Android x.x.x or iOS x.x.x), and the version of the app you are running (2.7.x, 2.8, or 2.8.1).
Hi Stephen,
The device is a Samsung A50.
One UI version: 1.1
Android version: 9
Kernel version: 4.14.62-16641116
Arlo app version: 2.8.0.25870
this isn't an OS version issue. this is an ARLO issue. look at everyone else having the same issue including myself
On my phone i can view the cameras Live. So connecting over 4g to the hub at my house is fine. Playing back anything that is in the Library...stored in the ARLO Cloud just buffers.
This is a big flaw that they need to resolve ASAP
Check the google play store, and see if there is an update pending for 2.8.1
Updated to 2.8.1 but the problem still persists unfortunately
Thanks, I am going to do the same. Load the old app and use it.
I'll let you know if it stops working again.
This is ridiculous.
I have also had an ongoing help request, hopefully still open, for this issue. I have not heard back in a couple of days but I send an update daily. I can only believe that they are aware of the situation and are working on it. At least I hope so.
Thank you for this recommendation. This actually works for me for now. I don't know what will happen after September 30 when they say it won't be supported any longer.
Oddly, the old app works, but the new app still does not. So that leads me to conclude most positively that the issue is with the app. It's not with OUR phones. It's not with OUR cameras or OUR equipment. The issue is almost definitely on the Arlo side.
I would encourage everyone with this problem to please go to support and open a case. I have mentioned this discussion to the person helping with my case, but I don't know if they read the community forums.
When and if I hear back regarding my case, I will post. Hopefully they will get this worked out soon.
