  • 1 Reply
  • 4039 Views
Khalil
I just ordered Arlo Pro Smart Home HD Wireless Security Camera 3-pack.
I would like to install these cameras behind the window (from inside the house to look outside), since they can easily be stolen, I prefer to have them inside the house looking out, however, I’m not sure if being behind a clear glass would cause any issues.  Do you see any problem with the night vision or any distortion in it resolution?  Would Arlo Pro Skins-Camera protective cover work or you have any other suggestion.  Thanks and appreciate any respond.
Arlo and Arlo PRO cameras will not DETECT motion thru glass..... they depend on IR as a detection source and glass block most of it.
Also if you use the IR illuminators ( night vision ) , the light will reflect off the glass and wash out the picture
The Q camera will work thru glass as you want as the detection mode is pixel based ( sees changes in picture ) , but even with the Q, you can not use the night vision
