What are the differences between VMS4330 and VMS3330? if I'm looking at the same number of cameras, I can't rell what the differences are between these tow models/lines. I assume the VMS4XXX is newer, which is why it costs more, but what am I gaining by purchasing the newer model?
The 4330 is the Arlo PRO ( newer ) version over 3330 Arlo... ( the packages are 3 cameras I believe )
The Pro model uses single rechargeable battery pack, has 2x audio , and the Pro Base has a siren and local record backup via usb
The Pro also has an improved detection over the older Arlo.
Arlo (older ) does not have audio or local record backup on the base , uses 4- 123 battery cells or rechargeable cells of the same size
