If you are starting to get 2 and 3 or 5 Notifications for 1 Alert and you find if you uninstall the app and reinstall it you get another one added so 5 turns into 6 notifications. youve found the solution.
Im on Android Oreo on the galaxy S9 plus but this applies to all android versions that have google back up enabled.
Here is how:
First Delete The Arlo App, then
Go into "Settings", "Cloud and Accounts", then "Backup and Restore",
Then down on the bottom theres a toggle thats says "automatic Restore"
Toggle that off.
Next, Click on "Google account" in the same menu
And at the top theres a toggle that says "back up to google drive". Slide it OFF
it will give you a warning that you are about to delete your backup
"Confirm and delete"
Next reboot the Phone
then go back to the last slider that we turned off that said "Back up to Google Drive" and turn it back on
Then Re download the arlo app and Log back in alls well.
Hope this helps i had 5 notifications for every alert equal to the time i uninstalled and reinstalled
force stop Arlo, clear cache, clear data (found under storage), restart Arlo it worked, so far, and easy to do. Galaxy s7 runniing Android 8.0, Oreo and running Google back-up
Thanks . Secaz
Thanks . Secaz
Thank you, Thank you, Thank you!!! This worked for me also. I also have the S7 running Oreo.
I am having same issues but with Iphone X. Wheever I get a motion and records it, the counter will say 15 instead of just a single event. I dont know why it replicates the notification. I also noticed that if I go directly to the device vs going to the library, IM not able to reset the counter. It will show 14 notifications ven after I already viewed the video clip. THe developers need to start getting hot with this. This must be a scripting error or something. Ive rebooted, re-added the app, logged out and logged backed in, Disarmed and re-armed. I even tried to reset my password and I never got the reset password email noitification either.
I dont know if this is a phone issue, Im seeing a lot of solution to do something with their phones. I have an iphone and im having same issues. This has something to do with the app or the router. We either need newer firmware or updates.
