If you are starting to get 2 and 3 or 5 Notifications for 1 Alert and you find if you uninstall the app and reinstall it you get another one added so 5 turns into 6 notifications. youve found the solution.
Im on Android Oreo on the galaxy S9 plus but this applies to all android versions that have google back up enabled.
Here is how:
First Delete The Arlo App, then
Go into "Settings", "Cloud and Accounts", then "Backup and Restore",
Then down on the bottom theres a toggle thats says "automatic Restore"
Toggle that off.
Next, Click on "Google account" in the same menu
And at the top theres a toggle that says "back up to google drive". Slide it OFF
it will give you a warning that you are about to delete your backup
"Confirm and delete"
Next reboot the Phone
then go back to the last slider that we turned off that said "Back up to Google Drive" and turn it back on
Then Re download the arlo app and Log back in alls well.
Hope this helps i had 5 notifications for every alert equal to the time i uninstalled and reinstalled
First uninstall it.
Next go to cloud and accounts in settings.
Next go to Google account. Next go to the third one down app data, it says automatic restore there push the slider off reboot your phone go back to the same spot make sure where it says app data the slider is off. Now now install Arlo best of luck
I chopped It Up by mistake sorry
If you just turn off the one that says restore app data. Before you install the app after you reboot make sure that slider is off. Then install . I followed those earliest steps to about 5 times. Then I looked into it and I just turned that one thing off before I installed it and then it works hope it works for you
Yes I know it's a bug I had seven notifications I also did one more thing before I installed it I went to the Samsung account there's also a spot there.
I turned off all of the automatic restore and backup for the Samsung account also. This way Samsung doesn't automatically restore the app the way it was. I'm not sure which one works but that's what I did and after my 7th try it worked. So after I rebooted I went back to the Google thing made sure the slider was off that says automatically restore app settings for the apps. Then I went to the Samsung account and unchecked all those boxes for automatic restore but I did not close it I just minimized it because if I close it and open it again all of the check boxes check rechecked. Then I installed and I was good
So basically the idea is we have to try to get Google and Samsung to stop restoring the settings on the app. And that's what I was working on and that's how I succeeded. Remember it may not be Google that's doing it Samsung also has a restore settings. So it could be both of them restoring the settings
@zsmith4 wrote:
Thank you for the clarification. I will try again and turn off the Samsung account as well
they just released a arlo app update, im not sure if it fixed this because i fixed mine from this post
but it does say various bug fixes
I didn't have this problem until today when I updated my app, I'm on marshmallow and now I'm getting 3 notifications per recording. This whole system had been broken since the May update and cannot be trusted as a security system any longer, when are they going to fix the multiple issues???
I've done this on multiple phones and it worked each time........
To fix multiple notifications on Android..........
Uninstall the Arlo app from Settings > Apps > Arlo (doesn't hurt to force stop it first)
Then go to: Settings > Cloud and Accounts > Backup and Restore
Then down on the bottom there’s a toggle that’s says "Automatic Restore", toggle it OFF
And at the top there’s a toggle that says, "Back up to Google Drive", toggle it OFF
It will give you a warning that you are about to delete your backup, "Confirm and delete"
Next, reboot the Phone
Then go back to the last slider that we turned off that said "Back up to Google Drive" and turn it back on
Then download and install the Arlo app and log back in
Then setup your arlo notification sound again and your good to go
You're right, Arlo needs to fix their app.
But if you want to try and fix it yourself instead of waiting who knows how long for Arlo to fix it......
The only other potential end user fix I have is to uninstall the app, download and install CCleaner, run a clean of your phone, reboot, install Arlo. Hopefully that will fix you up.
That "solution" is completely unacceptable. Fix the app or lose customers Arlo.
Both posts I made were not a "solution", they are referred to as end user fixes or workarounds. Many people who are tech savy don't bother with "support" or the likes, we find answers and fix our own issues. The two fixes I posted were posted in this forum by other people and I know they work.
Yes the app needs to be fixed and I also realize that you're frusted but waiting for Arlo to fix the app is just going to get you more frustrated. Why not try either of the fixes. If it works, great, you're not annoyed anymore. If it doesn't work then you'll have to wait until the app gets fixed, which is most likely won't happen for quite some time.
Arlo engineers do not read these user forums, nor does any of the issues reported here typically get reported to them. I'm not even sure they even know about this issue, If they did you'd think it would have been fixed months ago as it's just a simple programming bug.
OK, the work-around is unacceptable for me. I am not going to take those draconian steps, and the risks they involve.
I have a linux server with a special card for accepting 8 camera feeds and can run Zoneminder again if I feel like going to great lengths to roll my own solution. I went with Arlo because I was tired of maintaining that.
Arlo need to "just work". Otherwise it's going to be defenestrated.
Had to log back into the app, but it worked.
I went from 2 notifications per alert to one.
I'm sure many of you did this to no avail, but some might have luck with it like I did.
Good luck!
