  • 5 Replies
  • 7378 Views
  • 3 Likes
mvwedel
Hi, is it possible to deactivate having to enter the password every time I access the app? Thanks
5 REPLIES 5
As long as you're not actually logging out you shouldn't need to log in every time. Simply swipe/background the app instead of logging out.
mvwedel
Hi, thx. That is exactly the problem. I never log off and have to use my fingerprint or pw every time, whixh takes to long, if I want to e.g. talk to the mail guy quickly.
Try reinstalling the app and rebooting the phone.
mvwedel
thx, unfortunately didnt work.. Any idea on how to deactivate the password altogether?
Have you tried disabling the fingerprint login? No  other ideas so open a case with support here.
