May 29, 2019 Update
- Email to a Friend
- Email to a Friend
- Email to a Friend
- Email to a Friend
Same problem here. It's been happening ever since the last update.
- Email to a Friend
- Email to a Friend
@ToastyFlake wrote:
Why are you mentioning beta testers? It’s not working for people who are not on beta software.
I'm just been sarcastic, we are all Arlo's beta tester, get it?
- Email to a Friend
Hello,
My Geofencing feature on my Arlo detects when I leave home and arms itself, but does not detect when I return home and does not disarm itself. It used to work fine, but recently it stopped working. I don't know what happened. I have deleted the iOS apps on both iPhones and reinstalled them, but still the behavior is the same. It's set to Geofencing mode, to arm itself when I leave, and follow the schedule when I'm home.
Any help troubleshooting would be greatly appreciated.
- Email to a Friend
Does anyone know if today's software update fix the Georfencing issues that we have been experiencing?
- Email to a Friend
- Email to a Friend
- Email to a Friend
@BillTHollins wrote:
Over 200 entries just for this one thread, and same in other threads...
You may find that many of those other messages have been merged into this discussion.
Some people can't be bothered/don't know how to check for existing discussions so they start all over again.
The Netgear moderators may have been trying to keep things under control. Which sort of disproves this bit:
They ignore the user community, the support email and just carry on oblivious!!
Rest assured, they know about this problem.
My Arlo hardware: Q Plus, Pro 2 (X2), Security Light, Ultra, Doorbell, Chime
- Email to a Friend
"Rest assured, they know about this problem."
On the one occasion I did manage to get Live Chat working (Tuesday 28th May) I was told "I see, yes, we have some issues reported but good things is it has been rectified." and "Can we try to rename the device on your phone?". After she gave me few more detailed instructions I said "OK. I will try that. Will this be corrected in the next firmware update?". Her response was "Please do. It should be rectified after taking these steps.". So two days ago support was not aware of the issue.
- Email to a Friend
There is a new app update available this morning for download on my iPhone, the question is...does it fix the issue?
- Email to a Friend
- Email to a Friend
Geofencing works as expected when leaving the property ie the system is armed - when returning to the property I receive a notification that I am in the "home" geofence area but the system doesn't change the system status from armed to disarmed. The problem is the same for both users using the iphone app.
- Email to a Friend
I don't know anything about computers, so can someone tell me if, when the system is all working properly, I can do anything to stop Arlo messing it up again. Is there not a moto - if it isn't broken dont fix it. Why do they keep tinkering?
- Email to a Friend
I have the exact same issue with geofencing. It just started over the last week or two. I’m using a mix of Arlo and Arlo Pro cameras with an Arlo Pro Base and the iOS app.
- Email to a Friend
- Email to a Friend
"There is a new app update available this morning for download on my iPhone, the question is...does it fix the issue?"
NO
- Email to a Friend
- Email to a Friend
having same issue here. The one thing I did notice is that arlo geofencing shows "in zone" but when I look at the triangle on the map showing my location, it shows it about 3 blocks away. It isn't a problem with my gps because all other mapping programs show me within a foot of where i"m standing. Please fix asap.
- Email to a Friend
Our development team is investigating reports from users who are not able to use Geofencing as expected and will provide updates when available. We appreciate your patience and apologize for the inconvenience.
- Email to a Friend
- Email to a Friend
- Email to a Friend
All cameras just went offline (statis sais offline) but they are still registering movement and sending notifications.
Someone at arlo did something stupid again.
Edit: ”working” again.
Still geo is messed up. Need to deactivate and activate for it to change status. Sigh.
Dienste und Sicherung
FlexPower ONVIF Cameras
ReadyNAS for Surveillance
Switches For Surveillance
